Discovery West: Mixed-Use Development Downtown By Skanska
Moore713
On 6/17/2022 at 8:51 PM, scarface said:
It's not even about the niceness of the hotel that I was speaking of. It was the fact that they messed up the urban continuity of Discovery Green by having the butt end of that blank back wall facing the park. That was bad planning to have the back of the structure facing an urban park.
This Skanska development seems to be minimizing the whole E/S development and all of the design flaws that came with it.
I'm no architect, but it seems like at the end of the day they made a reasonable decision considering they didn't own the entire block.  I believe those windows are at the end of the hallway/corridor between the rooms.  Sure you could've wrapped windows around the entire building to create "corner rooms," but those windows are now not going to have much of a view anyway now.  At least on the southeast face of the building, you do have the pool deck creating space between the hotel and the new building.  But I'm probably giving them too much credit that they even thought about it.  It somewhat makes sense that when they may have been (oh who are we kidding?  I'm sure it's "certainly did" versus "may have been") value engineering that was the logical side to do it on.
Regardless, my point is not to defend the architecture--it's agreeably awful--just saying what's on the inside isn't bad, which should count for something.  I guess the Hampton Inn/Homewood Suites is a bit less awful, but similarly not very inspiring.
On 12/30/2021 at 9:54 AM, editor said:
It's about the same as L.A., when adjusted for size.  It's slower than Chicago, again when adjusted for size.  Chicago has been issuing permits for three to five new buildings in the 25 to 115-story range each month of the pandemic.
I read the Chicago permits each month, and this is the first month in a very very long time when there hasn't been a filing for a new skyscraper.  If you'd like to keep up on the Chicago action, this is a good place to start.
Here's what's been moving through the permit process since October:
Most of the development in Chicago is residential these days because the city has spent the last decade-and-a-half luring corporate headquarters to town.  A bunch of big-name companies that left the city in the 60's through 80's have moved back, (McDonald's, Caterpillar moving to Texas, Walgreens, Hormel) and it's also bringing in corporate headquarters from other cities (Boeing from Seattle moving to Northern Virginia ).
The influx of corporate headquarters spans multiple mayoral administrations.  It's the result of efforts by quangos with 30-year plans.
About six months in, I thought an update might be in order.   See updates in blue, above.
  • Thanks 3
17 hours ago, bobruss said:
From this angle it will look great!
Agree. It will make a great backdrop when facing south.  The ES was very boring, but being set back as far as it was, you had the gap of the parking lot providing the frame for that side of the park as much or more than the ugly box when you were over there. This parcel and the others immediately across the street really add to the atmosphere of the park. The Avenida promenade, The Hilton, Marriott, Hess, OPP and the new Parkside tower give us a nice scope and scale to round out the field of view.
  • The title was changed to Discovery West: Mixed-Use Development Downtown By Skanska
I was not expecting Skanska to bring out curtain wall with that much detail, depth and down right beauty!!!  Their past projects have all been a fairly conservative and simple facade designs but this is amazing.  It looks like they finally decided to build themselves a trophy tower.
Tangled, I think I've seen you reply to construction questions in the past:
Don't they typically test the glass before putting it on the building? It seems like they are moving fast, doesn't it?
4 hours ago, sapo2367 said:
Indeed -- here are their preliminary plans.
Wait, does the bike lane currently keep going up Polk St. and connect to Austin St.? This might be something new I hadn't seen before.
There is a temporary bike lane there at the moment -- orange traffic barriers to separate it from the road. They added it b/c the section on Lamar is closed during the construction work.
Quote
Long story short, yes the unitized system is always tested before getting installed.  What typically happens is you have a base system that has been lab "chamber" tested to perform to the required strength and water infiltration requirements.  Then as each project comes along and the gingerbread stuff like fins, extrusions, etc gets added the client can then decide if they want to pay for a whole new chamber test.
The full pull lab test is VERY expensive and time consuming, most developers try and avoid it by using previously tested systems.  Not sure whos curtain wall this is (there are only 5-7 companies that do this kind of work).
They will also do in place performance testing to make sure things arent leaking.
  • Like 4
  • Thanks 1
North Houston Line and Pole, hired by Centerpoint, keep parking their construction equipment in it. It has been very frustrating. I think the city is planning on keeping this connection after the project ends.
