Luminare Posted May 8, 2015 Share Posted May 8, 2015 Has anyone actually sent this to the developer or architects office? This is legitimately a grave concern! This is completely unacceptable! 2 Quote Link to comment Share on other sites More sharing options...
BigFootsSocks Posted May 8, 2015 Share Posted May 8, 2015 I can vaguely see a rope trailing down from his waist and he has a harness so I assume he was strapped in. The other guys...not so sure lol 1 Quote Link to comment Share on other sites More sharing options...
hindesky Posted May 9, 2015 Share Posted May 9, 2015 I think they are behind schedule but have been making up time since they started on the wood framing. It appears the floors are topped out but with the crown is still going up. 5 Quote Link to comment Share on other sites More sharing options...
ANTHONYHTOWN Posted May 10, 2015 Share Posted May 10, 2015 that was fast i also notice the old savoy which is going to be a holiday inn seems to have white curtains in some rooms? haven't heard much about that project but i am sure they are behind 1 Quote Link to comment Share on other sites More sharing options...
cspwal Posted May 10, 2015 Share Posted May 10, 2015 An entire block is a "small construction site"? Quote Link to comment Share on other sites More sharing options...
Purdueenginerd Posted May 10, 2015 Share Posted May 10, 2015 I can vaguely see a rope trailing down from his waist and he has a harness so I assume he was strapped in. The other guys...not so sure lol Event then, Body Belt fall arrest systems have been unnacceptable for fall arrest systems since like the late 90s for a couple of reasons why. When you fall, you accelerate quite quickly, the fall arrest system today are roughly designed for 5000 lbs of force. Thats not to say, that you weight 5000 lbs, you'll be safe. It means, that the force applied by a 300 lbs person falling 4-6 feet and stopping within a foot or two, will apply several thousand lbs of force to the arrest system. Body belts, are banned by OSHA (there are exceptions and this isnt one of them), because an inverted fall with 5000lbs of force on the arrest system will basically rip the belt down your legs or up your torso, and you die anyway. The other reason they were banned is because was if the body belt performed as such, it put incredible amount of stress on the hip bones, breaking the hip bones--- it also, could effectively annihilate internal organs with the equivalent of a 5000 lb punch to your stomach region. The recoil of a grown adult slamming his/her knees into their face at that velocity would knock most people unconscious, and it was determined that while many belts saved people from going splat on the pavement, their hanging position and injuries sustained by the belt they'd be dead within a minute from asphyxiation They should have a 6 point body hardness, at a minimum doing the work they're doing. Someone mentioned contacting the GC or owner of this project. I would encourage that. Either those guys are being knowingly reckless, or management is trying to cut corners on the backs of labor. https://www.osha.gov/pls/oshaweb/owadisp.show_document?p_table=NEWS_RELEASES&p_id=1078https://www.osha.gov/Region7/fallprotection/fall_protection_info.html 2 Quote Link to comment Share on other sites More sharing options...
Luminare Posted May 10, 2015 Share Posted May 10, 2015 Event then, Body Belt fall arrest systems have been unnacceptable for fall arrest systems since like the late 90s for a couple of reasons why. When you fall, you accelerate quite quickly, the fall arrest system today are roughly designed for 5000 lbs of force. Thats not to say, that you weight 5000 lbs, you'll be safe. It means, that the force applied by a 300 lbs person falling 4-6 feet and stopping within a foot or two, will apply several thousand lbs of force to the arrest system. Body belts, are banned by OSHA (there are exceptions and this isnt one of them), because an inverted fall with 5000lbs of force on the arrest system will basically rip the belt down your legs or up your torso, and you die anyway. The other reason they were banned is because was if the body belt performed as such, it put incredible amount of stress on the hip bones, breaking the hip bones--- it also, could effectively annihilate internal organs with the equivalent of a 5000 lb punch to your stomach region. The recoil of a grown adult slamming his/her knees into their face at that velocity would knock most people unconscious, and it was determined that while many belts saved people from going splat on the pavement, their hanging position and injuries sustained by the belt they'd be dead within a minute from asphyxiation They should have a 6 point body hardness, at a minimum doing the work they're doing. Someone mentioned contacting the GC or owner of this project. I would encourage that. Either those guys are being knowingly reckless, or management is trying to cut corners on the backs of labor. https://www.osha.gov/pls/oshaweb/owadisp.show_document?p_table=NEWS_RELEASES&p_id=1078https://www.osha.gov/Region7/fallprotection/fall_protection_info.html Awesome stuff you found. I had no idea about stuff like this. If anyone should be calling the GC or owner it should be astros148! Anyone of us could potentially contact them, but all we have to go by is the photo itself and could be passed off as us taking something out of context. The only way the photo sticks is if the person that took it put words behind it. Quote Link to comment Share on other sites More sharing options...
Nate99 Posted May 13, 2015 Share Posted May 13, 2015 9 Quote Link to comment Share on other sites More sharing options...
ANTHONYHTOWN Posted May 13, 2015 Share Posted May 13, 2015 WELL THAT WAS FAST. TOOK LESS THEN A MONTH ? COMPARE TO THE PREVIOUS MONTHS. Quote Link to comment Share on other sites More sharing options...
BigFootsSocks Posted May 13, 2015 Share Posted May 13, 2015 I KNOW. Quote Link to comment Share on other sites More sharing options...
cspwal Posted May 13, 2015 Share Posted May 13, 2015 The main thing that Block 334 has done has made that Goodyear look severely out of place Quote Link to comment Share on other sites More sharing options...
Tumbleweed_Tx Posted May 15, 2015 Share Posted May 15, 2015 Almost topped out. Are they going to put a tree on this one? 3 Quote Link to comment Share on other sites More sharing options...
BigFootsSocks Posted May 16, 2015 Share Posted May 16, 2015 (edited) They've got a few trees up already Edited May 16, 2015 by BigFootsSocks Quote Link to comment Share on other sites More sharing options...
Howard Huge Posted May 16, 2015 Share Posted May 16, 2015 They've got a few trees up already Stoner humor? Quote Link to comment Share on other sites More sharing options...
BigFootsSocks Posted May 16, 2015 Share Posted May 16, 2015 (edited) Stoner humor? Didn't even think of that Edited May 16, 2015 by BigFootsSocks 1 Quote Link to comment Share on other sites More sharing options...
cloud713 Posted May 16, 2015 Share Posted May 16, 2015 i think he might of been referring to the structure being made of wood? 2 Quote Link to comment Share on other sites More sharing options...
astros148 Posted May 16, 2015 Share Posted May 16, 2015 8 Quote Link to comment Share on other sites More sharing options...
hindesky Posted May 17, 2015 Share Posted May 17, 2015 Building is topped out they are working on the crown. 8 Quote Link to comment Share on other sites More sharing options...
ArchFan Posted May 17, 2015 Share Posted May 17, 2015 It's strange to think about a building in downtown Houston that appears to be almost completely made out of trees. OTOH, I guess trees were the most conspicuous part of the landscape there 200 years ago ... 1 Quote Link to comment Share on other sites More sharing options...
Ross Posted May 17, 2015 Share Posted May 17, 2015 It's strange to think about a building in downtown Houston that appears to be almost completely made out of trees. OTOH, I guess trees were the most conspicuous part of the landscape there 200 years ago ... There may have been trees near the bayou, but most of the area was potholed prairie 1 Quote Link to comment Share on other sites More sharing options...
Howard Huge Posted May 18, 2015 Share Posted May 18, 2015 Building is topped out they are working on the crown. It's about damn time!!! 2 Quote Link to comment Share on other sites More sharing options...
Gator Purify Posted May 18, 2015 Share Posted May 18, 2015 I love the density. A repaint job is the best thing that ever happened to Houston House. Now, if only 2016 Main could update its look from that off-white and brown... 1 Quote Link to comment Share on other sites More sharing options...
Nate99 Posted May 18, 2015 Share Posted May 18, 2015 I love the density. A repaint job is the best thing that ever happened to Houston House. Now, if only 2016 Main could update its look from that off-white and brown... I always thought that Houston House looked like the Jawa’s big tracked desert rover thing from the original Star Wars movie alone by itself in a sea of asphalt. Good that it is getting some neighbors. 5 Quote Link to comment Share on other sites More sharing options...
toxtethogrady Posted May 19, 2015 Share Posted May 19, 2015 I found something else that's going up faster than Block 334... 4 Quote Link to comment Share on other sites More sharing options...
DrLan34 Posted May 27, 2015 Share Posted May 27, 2015 Over the weekend 4 Quote Link to comment Share on other sites More sharing options...
Popular Post HoustonIsHome Posted June 1, 2015 Popular Post Share Posted June 1, 2015 Houston is one weird city. 10 Quote Link to comment Share on other sites More sharing options...
Popular Post astros148 Posted June 1, 2015 Popular Post Share Posted June 1, 2015 11 Quote Link to comment Share on other sites More sharing options...
Lestat Posted June 3, 2015 Share Posted June 3, 2015 I wonder what will go in the middle? A pool or just an open court yard? Quote Link to comment Share on other sites More sharing options...
HoustonIsHome Posted June 3, 2015 Share Posted June 3, 2015 Why not both? Quote Link to comment Share on other sites More sharing options...
Timoric Posted June 3, 2015 Share Posted June 3, 2015 (edited) - Edited July 9, 2019 by Timoric Quote Link to comment Share on other sites More sharing options...
