B-Cycle expansion and improvements are on the way!
The More You Know!
Thanks. Never knew there was one near the MFA but that makes so much sense and I am worried that I am very unobservant because I ride my trike through Hermann Park several times a week and have never noticed the station but do see riders all the time.
  • 3 months later...
B-Cycle nearly hits 100,00 riders in 2015
Houston’s growing bike sharing system – poised for a big 2016 – nearly pulled off 100,000 checkouts last year.
After adding two stations in the last weeks of the year, bringing the total to 31 kiosks and 190 bicycles, Houston B-Cycle logged 98,388 uses, according to organizers of the system. People can check out a bike with a pass – daily, weekly or annual – and use the bike without charge for 60 minutes. After that, the bike costs $4 per hour.
I rode B-Cycle for the first time here in Houston, and it was pretty fun! It's a few bucks cheaper than Austin's B-cycle for 24-hours (I have not yet tried it out there). My only remark is that I find it a bit silly that you have to "check-in" every 60 mins? Got the 24-hour pass and only used it for 3-hours or so, but every hour we had to go to a station and place them back on the rack and check them out again. Luckily there was multiple stations on our route so it really wasn't an inconvenience. I guess they figured that someone may take them home for 24-hours. Nearly every station was empty!
Also, quite a few drivers were driving into the bike lane turning from Austin St. onto Lamar near the Four Seasons!
As I understand it, you don't have to check in and out every 60 minutes, but they will charge $4 an hour after 60 minutes.  I think the concept wasn't so much having people check them out for hours at a time to just ride around but to check one out to go from point a to point b, check it in and do whatever and then check another one out for the next leg (or return leg) of your trip.
Maybe they should install a pole in the middle of the bike lane/on the stripe separating each side of bike traffic, at each intersection, so it's a wide enough space for bikes to easily travel by on either side, but too narrow/an obvious obstacle preventing vehicles from entering the lane?
I believe Houston's bike-sharing program is one of the, if not the number 1, most successful/profitable of the cities that have a program.
That may be true, I don't know.
B-cycle continues to need government subsidies though. In the short term, that is fine, in the longer term, it will need to be able to make a profit and generate sufficient cash flow for capital replacement and expansion. Hopefully they have a business model that accomplishes this over the next few years.
The good news is that they seemingly have the needed, short term expansion money locked in.
http://blog.chron.com/thehighwayman/2015/09/bike-sharing-program-poised-for-major-expansion/
most of the time I see people not using it to commute, but to enjoy. so they did get their model wrong. maybe they still want people to use it to commute, and the 1hr check-in is what will encourage this? I don't know.
I'm most hopeful that this program does more than just be profitable, I hope it encourages people to buy their own bikes (even if just walmart specials) to enjoy life.
Using it to commute is largely dependent on increasing the number of stations. Right now stations are located primarily at destinations; they need to also be easily accessible in comparatively residential areas, even just within midtown, Montrose, etc, but the big obvious one is the entirety of the Heights.
Even 100 stations will be too low to reach most people who could otherwise take advantage of Bcycle for commuting purposes. Compare 100 stations to the number of stations in the DC area, New York, or even Minneapolis.
WITH THAT BEING SAID, getting the total up to around 100, if carefully targeted, will make a huge difference. I'd like to see them keep the range pretty low to maximize station density, but we'll see.
I've always had the impression that the prime target isn't commuting as much as augmenting the metro system to help with last-mile type situations.  And/or to allow easy errand running by folks in the central core.  That being said, I seem to see the most b cycles in and around Hermann park in obviously leisure use.
  • 5 weeks later...
  • 5 months later...
They are expanding cause it's working. I see so many people riding them. For recreation, or for a quick trip. I'll grant that I mostly see them being used for recreating, but that's cause it's where I usually am to see them. On a BBP trail, or in Hermann park, people usually don't ride through these places on their way to the grocery store for a loaf of bread.
  • 1 month later...
Why not both?
I actually think it's useful to think of bikeshare as somewhat distinct from having your own bike, though they both benefit from the same infrastructure.
Bikeshare, at least when it's fully built-out, has one big advantage: no planning ahead is required. You just hop on, drop it off, and never worry about that particular bike being messed with or stolen, or where to lock it up, or having it with you whenever you need it. It's really not a replacement for owning your own bike; it's another option for short to medium distance trips (like Uber, bus, light rail, or potentially even walking) that you can take advantage of without having to plan ahead. And yes, it can also integrate incredibly well with longer-distance transit. Maybe you take park-and-ride in from somewhere in the greater suburban hellscape,  but the bus drops you off a mile from your office. You jump on a BCycle and you're there in no time.
Again, this is all predicated on there being enough station density that you never have to wonder where the nearest station is or worry that there won't be a station close enough to your destination, but, assuming that level of density, bikeshare can be incredibly convenient.
I have found them to be more trouble than they're worth. If you're with a few people and you're only making one short trip, uber is a much better alternative. It costs $5 for each bike, or you an do an uber, with a minimum charge of about $6. I rented one a while back to take up to the art car parade. We spent more time trying to find a check in station so we wouldnt get charged extra than we did watching the parade.
$65 for an annual membership, unlimited checkouts for free (while still following the time rules).
Yeah, the annual membership makes a huge difference, and, again, it's hard to get a feel for what these systems are really like from the Houston BCycle system as it exists now. There just aren't nearly enough stations for it to be terribly convenient.
Edited by Texasota
On 10/30/2016 at 7:14 PM, hindesky said:
Owning a bike or two is good, but you have to plan ahead to take it with you.  Having bike share stations that can help you go the last mile using public transit is a plus.
  • 8 months later...
I'm trying to purchase a one-month Houston membership online, but can't seem to do so.
When I try to log into Houston's system, it tells me to log into Fort Worth's system instead (where I purchased a previous membership). The problem is, I can't purchase a Houston membership there.
When I try to create a new account on Houston's site, it won't let me because I already have a B-cycle account.
What gives?
