hindesky Posted March 15, 2020 Share Posted March 15, 2020 I often ride down Stanford as my last leg going home and have passed these cheap stucco townhomes, I finally turned left on W. Pierce to check out the front and saws these collapsing townhomes right next to them. I don't think anyone ever moved as I think they instantly received water damage to them. They are now falling apart, the roof collapsed on the front portion. I wonder which shitty company built these water traps? In my riding around inside the loop I see hundreds of these cheap townhomes who have seen lots of water damage because of cheap construction and fly by night builders. The townhomes next to the new BBQ place on Leeland have major water damage and are undergoing major repair. DON"T BUY STUCCO TOWHOMES. This is not the climate for stucco. Move to Phoenix, Tuscon or any other desert climate if you want stucco. Brick, Hardie plank, or concrete will last for years. 4 2 Quote Link to comment Share on other sites More sharing options...
Ross Posted March 15, 2020 Share Posted March 15, 2020 The ones on Stanford are actually 1413 and 1415. 1416 is the older home across the street. Properties are owned by a different company than built them, so hopefully there will be some movement to demo and rebuild. I don't like stucco here at all. Wood, brick, or Hardi. 1 Quote Link to comment Share on other sites More sharing options...
HoustonMidtown Posted March 15, 2020 Share Posted March 15, 2020 Those actually look like there has been some work done on them since I saw them last (a couple months ago). Channel 13 did a segment about them a coupe months ago I previously owned a stucco townhome and never had issues in the 15 years I lived in it - all depends on how the stucco was installed/applied - there are people/companies that can do it correctly 1 Quote Link to comment Share on other sites More sharing options...
mkultra25 Posted March 15, 2020 Share Posted March 15, 2020 3 hours ago, HoustonMidtown said: I previously owned a stucco townhome and never had issues in the 15 years I lived in it - all depends on how the stucco was installed/applied - there are people/companies that can do it correctly True, but unfortunately they tend to be outnumbered here by those who can't. The latter view it as a cost-saving measure, rather than something that requires skill and care to deliver a result that will withstand the local climate. 3 Quote Link to comment Share on other sites More sharing options...
Triton Posted March 16, 2020 Share Posted March 16, 2020 On 3/14/2020 at 7:15 PM, hindesky said: I often ride down Stanford as my last leg going home and have passed these cheap stucco townhomes, I finally turned left on W. Pierce to check out the front and saws these collapsing townhomes right next to them. I don't think anyone ever moved as I think they instantly received water damage to them. They are now falling apart, the roof collapsed on the front portion. I wonder which shitty company built these water traps? In my riding around inside the loop I see hundreds of these cheap townhomes who have seen lots of water damage because of cheap construction and fly by night builders. The townhomes next to the new BBQ place on Leeland have major water damage and are undergoing major repair. DON"T BUY STUCCO TOWHOMES. This is not the climate for stucco. Move to Phoenix, Tuscon or any other desert climate if you want stucco. Brick, Hardie plank, or concrete will last for years. Since I know you are on Reddit, you should post this to /r/Houston Quote Link to comment Share on other sites More sharing options...
hindesky Posted March 16, 2020 Author Share Posted March 16, 2020 9 hours ago, Triton said: Since I know you are on Reddit, you should post this to /r/Houston I did but I think it was removed Quote Link to comment Share on other sites More sharing options...
rechlin Posted March 17, 2020 Share Posted March 17, 2020 15 hours ago, hindesky said: I did but I think it was removed I have reinstated it. I don't know why it was removed. 1 Quote Link to comment Share on other sites More sharing options...
HoustonMidtown Posted April 11, 2020 Share Posted April 11, 2020 (edited) Finally.....they sliced off the front, damaged parts Untitled by Houston Midtown, on Flickr Edited April 11, 2020 by HoustonMidtown 4 Quote Link to comment Share on other sites More sharing options...
hindesky Posted April 12, 2020 Author Share Posted April 12, 2020 7 hours ago, HoustonMidtown said: Finally.....they sliced off the front, damaged parts Untitled by Houston Midtown, on Flickr Would any of you guys and gals buy what is left of these even if they rehab them? I know I wouldn't. 3 Quote Link to comment Share on other sites More sharing options...
BeerNut Posted April 13, 2020 Share Posted April 13, 2020 If they weren't boarded up so well vagrants would have burned them to the ground long time ago. 1 Quote Link to comment Share on other sites More sharing options...
HoustonMidtown Posted May 24, 2020 Share Posted May 24, 2020 Not much change....still very open concept !! Untitled by Houston Midtown, on Flickr On 4/13/2020 at 12:27 AM, BeerNut said: If they weren't boarded up so well vagrants would have burned them to the ground long time ago. Like these on LaBranch Untitled by Houston Midtown, on Flickr 1 Quote Link to comment Share on other sites More sharing options...
j_cuevas713 Posted May 24, 2020 Share Posted May 24, 2020 4 hours ago, HoustonMidtown said: Not much change....still very open concept !! Untitled by Houston Midtown, on Flickr Like these on LaBranch Untitled by Houston Midtown, on Flickr Is that Detroit? 1 Quote Link to comment Share on other sites More sharing options...
BeerNut Posted May 25, 2020 Share Posted May 25, 2020 12 hours ago, HoustonMidtown said: Like these on LaBranch Yep that's the ones I was referencing. I took several pictures of those in the Midtown forum More coming to Midtown thread. I even reported it to 311 several times because I was concerned that they would catch fire and burn adjacent homes. Quote Link to comment Share on other sites More sharing options...
Triton Posted June 9, 2020 Share Posted June 9, 2020 On 5/24/2020 at 9:46 AM, HoustonMidtown said: Not much change....still very open concept !! Untitled by Houston Midtown, on Flickr Like these on LaBranch Untitled by Houston Midtown, on Flickr Bike past the midtown ones all the time. All the homes there are nice in the area... I would absolutely hate having to see that everytime I got out of my home or looked out the window. 4 Quote Link to comment Share on other sites More sharing options...
hindesky Posted April 22, 2021 Author Share Posted April 22, 2021 So I was riding down Stanford and saw a roll-off trash bin and another around the corner. Talked with a guy about what they were doing and he said they were going to fix them all. Seems hard for me to believe that these can be rehabbed. They have a ton of water damage. I feel sorry for the people that they con into buying these. 1 1 1 Quote Link to comment Share on other sites More sharing options...
dbigtex56 Posted April 23, 2021 Share Posted April 23, 2021 21 hours ago, hindesky said: Seems hard for me to believe that these can be rehabbed. They have a ton of water damage. I feel sorry for the people that they con into buying these. I've always wondered how the reanimation of these zombie buildings works out. The townhomes in the 1700 block of Montrose sat half-completed for many years before someone finally finished them and put them on the market. They're occupied but I'd be interested to know what issues (if any) the owners have encountered. 1 Quote Link to comment Share on other sites More sharing options...
j_cuevas713 Posted April 23, 2021 Share Posted April 23, 2021 34 minutes ago, dbigtex56 said: I've always wondered how the reanimation of these zombie buildings works out. The townhomes in the 1700 block of Montrose sat half-completed for many years before someone finally finished them and put them on the market. They're occupied but I'd be interested to know what issues (if any) the owners have encountered. I wouldn’t be able to live there even with repairs. Quote Link to comment Share on other sites More sharing options...
hindesky Posted May 5, 2021 Author Share Posted May 5, 2021 I talked with a worker, he said he was exposing the damaged areas and someone else walking by said that a city inspector would determine the work needed to rehab the townhomes if they were repairable. I still don't think they will be able to fix these IMHO. Notice the metal pipe holding up the corner with the most damage. Looks like it could collapse any second. Quote Link to comment Share on other sites More sharing options...
hindesky Posted May 7, 2021 Author Share Posted May 7, 2021 I wish I was a City of Houston Inspector that wasn't taking money under the table, I would "FAIL" these townhomes so hard they would be torn down. These pics are from the Stanford St side. The pic I took of the northern townhome looks like it's "The Leaning Tower of Pisa". Water rot is beyond repair according to my honest inspector's license. Quote Link to comment Share on other sites More sharing options...
hindesky Posted May 9, 2021 Author Share Posted May 9, 2021 No workers so I could get closer. They have a hole which looks up into the floor above on one of the Stanford St. While I was taking these pics some guy driving by stopped and he said the developer is fighting lawsuits by the investors. Guy claims the developer is trying to save his ass by patching it up and tying it up in the lawsuit. It looks worse when you see it closeup. 1 3 Quote Link to comment Share on other sites More sharing options...
hindesky Posted May 13, 2021 Author Share Posted May 13, 2021 1 Quote Link to comment Share on other sites More sharing options...
dbigtex56 Posted May 15, 2021 Share Posted May 15, 2021 That's the ticket. A couple of lally posts and some spackling, she'll be good as new. 3 Quote Link to comment Share on other sites More sharing options...
mkultra25 Posted May 15, 2021 Share Posted May 15, 2021 3 hours ago, dbigtex56 said: That's the ticket. A couple of lally posts and some spackling, she'll be good as new. With the right contractors, anything is possible. 4 Quote Link to comment Share on other sites More sharing options...
hindesky Posted May 22, 2021 Author Share Posted May 22, 2021 I'm so glad they put that plastic over it to prevent any further damage. The only thing holding that side is the pipe. 2 1 Quote Link to comment Share on other sites More sharing options...
dbigtex56 Posted June 2, 2021 Share Posted June 2, 2021 On 5/21/2021 at 8:38 PM, hindesky said: I'm so glad they put that plastic over it to prevent any further damage. Someone asked The Furniture Guys how to fix damaged particle board. They replied "You don't. It's like trying to fix a piece of broken toast." When is the developer going to realize that these buildings are toast? Quote Link to comment Share on other sites More sharing options...
hindesky Posted June 6, 2021 Author Share Posted June 6, 2021 Added new boards but is going to keep them from rotting out due to water damage? I feel sorry for whoever gets conned in to buying the crappy townhomes. 1 Quote Link to comment Share on other sites More sharing options...
hindesky Posted June 12, 2021 Author Share Posted June 12, 2021 Quote Link to comment Share on other sites More sharing options...
hindesky Posted June 13, 2021 Author Share Posted June 13, 2021 1 Quote Link to comment Share on other sites More sharing options...
hindesky Posted August 8, 2021 Author Share Posted August 8, 2021 Quote Link to comment Share on other sites More sharing options...
dbigtex56 Posted August 13, 2021 Share Posted August 13, 2021 Once they've completed putting lipstick on this piggy and take it to market, will the sellers be required to disclose the extent of the repairs needed to get an occupancy permit? Or will it be as if those years spent open to the elements never happened? 1 Quote Link to comment Share on other sites More sharing options...
