Arctic Front heading our way!
HtownWxBoy
A very strong cold front is forecast to push across the Houston area on Thursday. Temperatures will fall through the 30s on Thursday behind the front. Friday and Saturday will see lows in the teens and 20s and highs in the 30s... some areas may stay below freezing all day on Friday. Sunday morning could also be in the 20s with milder conditions by Sunday afternoon.
Don't forget about water pipes... exposed pipes could break! :doh:
Dang - and here I was a total believer in Global Warming and rising sea levels that I removed the heaters from my house so that I could buy pontoons for the house to prepare for the rising seas. Now Im going to freeze to death. Oh well...gotta go some way or another.
We will, no doubt, lose many tropical plants - that's what I hate. We haven't had such a hard freeze in so long that many have been flourishing and pleasing my eyes.
Super hot summer and super cold winter, go figure. Not to take this off topic, sevfiv, but I recall these trends to be, in fact, part of global warming. Either way, my body does not like it.
This winter stinks so bad. What happened to our mild winters? I was over this winter before it started.
Dunno, seems like the usual bipolar Houston winter to me. I was in shorts and a t-shirt not so long ago. I just don't want to wake up to 60 degrees on marathon day!
A change in scenery isnt so bad. I've enjoyed these colder days.(for lack of a better word) Not what we usually expect in a Houston winter. And, hey, it could be worse, we could be Dallas!!ohmy.gif
Not this change of scenery. I don't enjoy looking outside and seeing the deadness. I get depressed. Anywhere I go I have to stay indoors because I can't tolerate the cold. In order to be comfortable I almost have to be hot. I like the heat. Where's the relief? I can't take this much longer.
Most of the real tropical species were hit very hard by the December 5th freeze, so I don't see that much extra damage on this event. During the mid 20s of the December event, the plants and palms especially were still really in growth mode which is why that freeze was so hard on them. By now they've slowed down and hardened off a bit.
I saw burned Royals, Majesty, Foxtails, Kings, and fishtails all over Houston after the December event. All of those palms should expect 100% defoliation unless you're real close to Galveston. I imagine a lot of the Royals for instance will die outright after this, but obviously you're pushing the limits with that stuff.
In the more subtropical species, I doubt any Canary Island or True Date Palms will die from this event, even up to say the Woodlands. I wouldn't be surprised by some light burn on those though. They're slow to recover and have large canopies so this may be an eye sore for a bit. The northwestern suburbs will lose some Queens no doubt, but inside the loop I bet you'll get only light damage. Mexican Fan palms north of 59 will get some burn. California fan palms will be entirely unaffected. Hybrids will have intermediate damage. Texas or Florida Sabals will both sail through this event unaffected. There are some beautiful Bismarckias around town that are going to get a bit fried, but established ones should survive at least from Houston proper south. Pindos, Mediterranean Fan Palms, and Brahea Armatas should be fine.
I'd try to protect bougainvillea anywhere around town with at least a blanket or frost cloth. North of town I'd put a blanket over Sagos too, otherwise it may be an ugly brown until late spring.
Jason
Jason
Good post Jason. I'm going to at least give my Queen (about 15') a good wrap around her trunk and hope for the best. My Pindo should handle the freeze easily as long as we don't get into the teens.
More cold, please. God, I love this weather.
EDIT: And if your plants die, well then it just wasn't meant to be. It just wasn't part of God's plan for them, now was it? Oh well. Let mother nature run its course.
Edited by BryanS
I have a pygmy date palm that got burned in the Dec. freeze, but I think they have a hardiness of 20 degrees so it should be fine. I also planted a queen palm over the summer and it still looks ok. I think they also have a hardiness of about 20. They're both planted next to a fence, if that matters. Now my papaya, that should do dandy.
I'm ready for this artic front. I'm ready for it to come, do its thing and hopefully get out. I just want it to be over with. I'd so love to see next week's forecast and it be nothing but days above 65 and sunny. I'd go outside and roll around on the ground, cat poop and all. It's funny because merely months anything below 70 I considered freezing. Now 60 looks downright toasty.
Edited by KimberlySayWhat
Do I need to protect my pool pump gear and stuff? Maybe it is best to keep the installation running?
Keep it running. Mine has a system that starts the pump as soon as air temp hits 36 no matter what the water temp is.
How do you protect the pipes, cover them up? My 1938 house only has exposed pipes .....
if you don't have insulation drain them as much as you can. it's usually easy to do the cold water pipes since the outside faucets are low points in the system. the hot water is another story though since most don't have hot water outside.
tonight i've also blocked the vents at the top of the roof to try and slow attic heat loss for the next few days. don't do it long term though as moisture problems could develop. according to a couple of thermometers I have inside, the temperature is higher than normal.
It's so cold that my heater cannot keep up. It has run continuously all afternoon, but the inside temperature has remained at 64. Not to mention that drafty windows feel much draftier in this weather. I just attacked several of them with duct tape. Must have worked. The thermostat now reads 65.
I've been running mine non-stop and it still dropped to 65 overnight, which I find borderline bearable with several layers. I kinda wish I had a snuggie now.
You gonna be ok Red? Got enough blankets and all?
I'm in the exact opposite circumstance. The thermostat is in the coldest spot in the apartment and duct to my room is inappropriately large, so even with the vent mostly closed-off, I have to keep the window open and vent the excess heat to keep comfortable. And all I'm wearing are scrub bottoms and a cotton t-shirt.
