Heights Home Questions
Has anyone built a small wooden backyard deck ?
How difficult would it be to build a 10 x 10 maybe 2 foot high wooden deck ?
Is this a costly project or better to hire a pro ?
Yep. I built a 10x22 foot deck, approximately 20 inches high. Not too tough, if you don't mind lifting heavy 2x6s and concrete blocks. Measure twice, cut once. :D
Cost was about $900, or $4 per foot. I used concrete blocks for the foundation instead of pilings. Much easier. Pilings are stronger though.
Professionals charge about $8 per foot.
Here's what I used. Dek-Block Available at Lowe's or Home Depot.
Edited by RedScare
Good Afternoon,
hope your day goes well !
Its me again seeking some of your exp, advice, opinions
Is it possible to use slate tile for a stand up shower on the walls and floor ?
I have noticed that when I use the shower there is a leak coming into the bedroom ?
The shower is built of slate tile all around .
thank you
Good Afternoon,
thank you
Doesn't really matter what sort of tile you use. What really counts is the membrane or other material you use to make sure that water doesn't go anywhere but the drain.
http://www.thetiledoctor.com/howto/showers.cfm
  • 4 weeks later...
thank you
Yes you can use slate. since we don't know where the leak is coming from you could have a variety of problems. does the shower have a proper drain pan under the floor so that water is directed to the drain? is the wall that the slate attaches to waterproof? does this same wall drain into the drain pan? sorry for asking questions but we need more info.
Hello All,
is there an easy solution to ease the noise on loose boards on wooden floors ?
thank you
you can go in a put deck screws from the bottom. just make sure they are shorter than the thickness of the floor (so they don't come of of the floor) but long enough to secure the top layer.
