Posted
Judging by current travel times, going from Wheeler to the Galleria would probably take about 25 minutes, but you're right once you add in taking the train there from downtown plus waiting for the connection, it could easily be 45 minutes
Posted
Lol cut and cover has and is being used in cities much more important than Houston. Westheimer is not champs elysees calm down.
Which "important" cities are currently doing cut and cover? There's a reason London hasn't done cut and cover for over 100 years. It's very disruptive. Deep tunnels are a better choice.
Posted
A quick web search turned this up
http://publictransport.about.com/od/Glossary/a/The-Two-Methods-Of-Subway-Construction.htm
Because of the negative community sentiment that often accompanies "cut and cover" construction, almost all new subway construction is done using the "deep bore" method. One exception was Vancouver B.C.'s recently opened Canada Line, and proves to be an excellent example of problems caused by the disruptive nature of the "cut and cover" method
Posted (edited)
Vancouver did it recently. Auckland New Zealand also
Edited by Slick Vik
Posted
Auckland built 3.4km of rail, with about a third cut and cover, the rest bored. That's not much rail. Vancouvers mayor promised no more cut and cover, do I'm guessing it was not a popular construction method there.
Posted
Qatar's metro rail projects are all using cut and cover
Posted (edited)
No, they aren't. The Lusail project will be cut and cover, the rest will be bored tunnels according to the project website
http://www.qr.com.qa/English/Projects/Pages/Tunnelling.aspx
Lusail is not a populated area, so cut and cover isn't disruptive.
Here's a story about one of the 21 boring machines being damaged by tunnel flooding http://dohanews.co/doha-metro-boring-machine-damaged-in-unexpected-tunnel-flood/
Edited by Ross
Posted
I know they did cut and cover in DC and people didn't like it.  But I don't think that should stop anyone from constructing a subway if the only viable method is cut and cover.
Posted (edited)
Delhi, Jaipur, Bangalore. I can keep going. It may be disruptive but I would rather have a rail line built with cut and cover then nothing at all. Also boring is prohibitively more expensive.
Regardless you're against rail so it's just another excuse from you.
Edited by Slick Vik
Posted
Delhi appears to be using 19 TBM's for tunneling, and cut and cover for stations.
I am not against rail per se, just against rail done stupidly.
Posted
I think it's more about economics than stupidity.
