TheNiche Posted May 25, 2006 Share Posted May 25, 2006 I actually see similarities between that and the existing Woodlands street layout: the cul-de-sacs, the linear spokes, the curved thoroughfares.Cool. Would you mind posting a map showing the pattern? I'd be very interested in seeing this. Quote Link to comment Share on other sites More sharing options...
SpringTX Posted May 25, 2006 Author Share Posted May 25, 2006 Cool. Would you mind posting a map showing the pattern? I'd be very interested in seeing this.I went to MapQuest and entered 77380 and this is the first map it showed me: http://www.mapquest.com/maps/map.adp?zipcode=77380You can see the cul-de-sac ciliae which give the map a cracked appearance. You can the semi-circular thoroughfare of Millbend from which many of them sprout. And you can see the linear roads.If you do zip code 77381 (http://www.mapquest.com/maps/map.adp?zipcode=77381), and look especially on the eastern and northern portions of the map, you see most of the poorly-formed circle that is Panther Creek Drive and its twigs and branches. North of Lake Woodlands Drive, you can see Golden Shadow Circle Quiet Oak Circle, and Shadowpoint Circle each have a similar effect. Quote Link to comment Share on other sites More sharing options...
TheNiche Posted May 25, 2006 Share Posted May 25, 2006 I went to MapQuest and entered 77380 and this is the first map it showed me: http://www.mapquest.com/maps/map.adp?zipcode=77380You can see the cul-de-sac ciliae which give the map a cracked appearance. You can the semi-circular thoroughfare of Millbend from which many of them sprout. And you can see the linear roads.If you do zip code 77381 (http://www.mapquest.com/maps/map.adp?zipcode=77381), and look especially on the eastern and northern portions of the map, you see most of the poorly-formed circle that is Panther Creek Drive and its twigs and branches. North of Lake Woodlands Drive, you can see Golden Shadow Circle Quiet Oak Circle, and Shadowpoint Circle each have a similar effect.Sorry, but I'm not seeing it. Quote Link to comment Share on other sites More sharing options...
SpringTX Posted May 26, 2006 Author Share Posted May 26, 2006 Sorry, but I'm not seeing it.It's ok. Your idea is on a whole nother level from everything in existence today. If a designer hasn't attempted a city based on triangles in 5,000 years of human history, I can't imagine anyone ever attempting one based on a pre-designed, naturally-generated fractal pattern. Some ideas are just too advanced for everyday use, I guess. Maybe people don't like to try complicated things out of fear of failure. Quote Link to comment Share on other sites More sharing options...
TheNiche Posted May 26, 2006 Share Posted May 26, 2006 It's ok. Your idea is on a whole nother level from everything in existence today. If a designer hasn't attempted a city based on triangles in 5,000 years of human history, I can't imagine anyone ever attempting one based on a pre-designed, naturally-generated fractal pattern. Some ideas are just too advanced for everyday use, I guess. Maybe people don't like to try complicated things out of fear of failure....lack of financing, actually. Quote Link to comment Share on other sites More sharing options...
SpringTX Posted May 27, 2006 Author Share Posted May 27, 2006 ...lack of financing, actually. Would a simple street plan based on, say, triangles be that much more expensive than a street plan based on rectangles? 3 sides instead of 4 = 25% fewer sides Quote Link to comment Share on other sites More sharing options...
TheNiche Posted May 27, 2006 Share Posted May 27, 2006 Would a simple street plan based on, say, triangles be that much more expensive than a street plan based on rectangles?3 sides instead of 4 = 25% fewer sides It has fewer sides but more paved land area. I think that the ideal pattern would fit hexagonal shapes together in the most efficient pattern, which would leave triangular gaps between them that would total one seventh the size of each hexagon. Short cul-de-sacs would penetrate each of the component six trangles that make up each of the hexagons. The triangular excess would be park land and every cul-de-sac would empty onto one of the parks. The pattern also encourages very efficient traffic flow and pedestrian movements within the neighborhood. When I mentioned financing though, I was really referring to the problems that a lot of folks face in trying to finance a project that is unique. Lenders tend to shy away from uniqueness because such projects carry risk that is difficult to quantify. Quote Link to comment Share on other sites More sharing options...
