IntheKnowHouston Posted March 19 Share Posted March 19 4309 Washington Ave is located an 0.05 acre parcel between Thompson St and Snover St. It's a grassy, vacant lot next to several townhomes on Thompson St. The grassy lot is also comprised of the following parcels at: 4311 Washington Ave (0.04 acres) 4313 Washington Ave (0.04 acres) 4315 Washington Ave (0.04 acres) 4317 Washington Ave (0.05 acres) Combined, the parcel total 0.22 acres. A block from these properties is Laredo Taqueria. The restaurant is located at 915 Snover St. 1 Quote Link to comment Share on other sites More sharing options...
IntheKnowHouston Posted March 19 Author Share Posted March 19 Below is a map outlining the following parcels: 4313 Washington Ave 4315 Washington Ave 4317 Washington Ave 4319 Washington Ave 0 Washington Ave Mao with street addresses associated with the aforementioned parcels. 4309 Washington Ave (on the 4313 Washington Ave parcel) 4311 Washington Ave (on the 4315 Washington Ave parcel) 4313 Washington Ave (on the 4317 Washington Ave parcel) 4315 Washington Ave (on the 4319 Washington Ave parcel) 4317 Washington Ave (on the 0 Washington parcel) Quote Link to comment Share on other sites More sharing options...
IntheKnowHouston Posted March 19 Author Share Posted March 19 April 2023 Google Earth image of the following parcels 4313 Washington Ave 4315 Washington Ave 4317 Washington Ave 4319 Washington Ave 0 Washington Ave Quote Link to comment Share on other sites More sharing options...
IntheKnowHouston Posted March 19 Author Share Posted March 19 November 2022 Street View images of 4309-4317 Washington Ave 1 Quote Link to comment Share on other sites More sharing options...
IntheKnowHouston Posted March 19 Author Share Posted March 19 There is a proposed Class 2 subdivision replat (C2R) for the following parcels: 4313 Washington Ave 4315 Washington Ave 4317 Washington Ave 4319 Washington Ave 0 Washington Ave The plat was submitted to city's planning department in late February. Plat Tracker lists the applications status as awaiting completeness. According to the Plat Tracker guide, the designation means "the application and/or documents did not meet Plat Tracker criteria or required documents are missing," according to the Plat Tracker guide. The subdivision name of the proposed plat is Equilent 2404. Quote Link to comment Share on other sites More sharing options...
IntheKnowHouston Posted March 20 Author Share Posted March 20 (edited) 14 hours ago, IntheKnowHouston said: There is a proposed Class 2 subdivision replat (C2R)...The subdivision name of the proposed plat is Equilent 2404. According to the city's Plat Tracker map, a proposed subdivision plat named Swan Terrace was submitted to the city in 2015. It seems developers were planning to build townhomes or some kind of residences on the properties. County records; however, indicate Equilon Enterprises LLC and Shell Oil Products US acquired the properties in November. In addition to warranty deed records, there is also a record of a termination of common area agreement filed in November. The agreement discontinues previous arrangements for the creation "of a homeowner association...to provide for general maintenance and upkeep of designated common areas on the premises... as commonly provided for residential property." The document also states "Equilon intents to replat and develop the premises as commercial property." I'm assuming the properties could be for the construction of charging stations for electric cars (EV charging stations). @HNathoo speculated as much in a topic pertaining to two downtown properties Equilon Enterprises and Shell Oil Products US own. The entities purchased 208 Main St and 214 Main St earlier this year. HNathoo's guess is it will probably become an EV charging station. Below is the previous plan for what was likely going to be townhomes. The plan is included in the termination of common area agreement: Edited March 20 by IntheKnowHouston 1 Quote Link to comment Share on other sites More sharing options...
IntheKnowHouston Posted March 28 Author Share Posted March 28 On 3/20/2024 at 3:14 AM, IntheKnowHouston said: I'm assuming the properties could be for the construction of charging stations for electric cars (EV charging stations). @HNathoo speculated as much in a topic pertaining to two downtown properties Equilon Enterprises and Shell Oil Products US own. The entities purchased 208 Main St and 214 Main St earlier this year. HNathoo's guess is it will probably become an EV charging station. Houston Chronicle reports on Shell expanding its electric vehicle charging network in the U.S. It doesn't mention anything Houston-specific, but it possibly relates to plans for the properties at 4309-4317 Washington Ave. As mentioned above, Shell acquired the following properties last fall: 4309 Washington Ave 4311 Washington Ave 4313 Washington Ave 4315 Washington Ave 4317 Washington Ave It's possible the oil and gas company may have plans to build electric charging stations here. https://www.houstonchronicle.com/business/energy/article/shell-ev-charging-gas-station-19367192.php 1 Quote Link to comment Share on other sites More sharing options...
hindesky Posted April 24 Share Posted April 24 https://shellrecharge.com/en-us/solutions Engineers - https://wbengineering.com Quote Link to comment Share on other sites More sharing options...
IntheKnowHouston Posted April 25 Author Share Posted April 25 (edited) On 3/20/2024 at 3:14 AM, IntheKnowHouston said: I'm assuming the properties could be for the construction of charging stations for electric cars (EV charging stations). @HNathoo speculated as much in a topic pertaining to two downtown properties Equilon Enterprises and Shell Oil Products US own. The entities purchased 208 Main St and 214 Main St earlier this year. HNathoo's guess is it will probably become an EV charging station. On 3/28/2024 at 9:29 AM, IntheKnowHouston said: Houston Chronicle reports on Shell expanding its electric vehicle charging network in the U.S. It doesn't mention anything Houston-specific, but it possibly relates to plans for the properties at 4309-4317 Washington Ave. As mentioned above, Shell acquired the following properties last fall: 4309 Washington Ave 4311 Washington Ave 4313 Washington Ave 4315 Washington Ave 4317 Washington Ave It's possible the oil and gas company may have plans to build electric charging stations here. https://www.houstonchronicle.com/business/energy/article/shell-ev-charging-gas-station-19367192.php 11 hours ago, hindesky said: https://shellrecharge.com/en-us/solutions Engineers - https://wbengineering.com Thanks for the update, @hindesky. Shell Recharge, an EV charging station, is indeed in planning for the properties at 4309-4317 Washington Ave. The filing lists Shell Recharge's Washington Corridor address as 4315 Washington Avenue. Edited April 25 by IntheKnowHouston Quote Link to comment Share on other sites More sharing options...
IntheKnowHouston Posted Tuesday at 07:16 AM Author Share Posted Tuesday at 07:16 AM On 4/24/2024 at 11:36 AM, hindesky said: https://shellrecharge.com/en-us/solutions Engineers - https://wbengineering.com Following last week's architectural barriers project filing, a plan reviewing fee permit was purchased for 4315 Washington Ave yesterday. Details from the permit: Use: New shell building, EV charging station The listed occupant on the permit is Equilon Enterprises LLC. As mentioned, the permit is for Shell Recharge. Shell Recharge is an electric vehicle charging station. Quote Link to comment Share on other sites More sharing options...
