matty1979 Posted April 27, 2012 Share Posted April 27, 2012 How would I find out who all lived in the house I grew up in? It was built in 1960 and we moved in in 1982. HCAD only has records back to 1988. Where should I look for this info? Thanks!! 1 Quote Link to comment Share on other sites More sharing options...
TheNiche Posted April 28, 2012 Share Posted April 28, 2012 You can trace courthouse records (try courthousedirect.com) pretty far back to figure out who owned the house, but it may be more difficult to determine who lived there if it might've been leased out. Quote Link to comment Share on other sites More sharing options...
little frau Posted April 28, 2012 Share Posted April 28, 2012 Also, the Harris County Clerk's site, www.cclerk.hctx.net has records back to the early 60s. You'll need the Block # and Lot # and possibly the subdivision where the house is located. Those bits of information are on HCAD. Quote Link to comment Share on other sites More sharing options...
Ross Posted April 28, 2012 Share Posted April 28, 2012 I use th ecounty clerk's site on th elink above. I take the current owners, an dsearch for tham as the grantee, and confirm the lot and block number. I then take the grantor and go through the same steps again with the grantor as the grantee. Watch for changes in spelling. Quote Link to comment Share on other sites More sharing options...
sevfiv Posted May 1, 2012 Share Posted May 1, 2012 The County Clerk database can work but it can be clunky - like mentioned above, you can find the earliest owner on HCAD then retro search grantor/grantees and if it's a common name and you get lots of hits, you can use the "Subdivision/Description" field for the neighborhood name (HCAD's "legal description." The older the record, though, the less uniform the entry (names and subdivisions).City directories will show tenants which could help, too.I have 1963 and 1976 directories handy - if you PM the address I can give you the information.. Quote Link to comment Share on other sites More sharing options...
matty1979 Posted May 2, 2012 Author Share Posted May 2, 2012 Address is 10626 Burgoyne..in Walnut Bend..77042. The furthest back I could find was 8/1971 and Butler was the people's last name.I would really like to know how to see an original exterior picture of the house. Thanks for the help! Quote Link to comment Share on other sites More sharing options...
Ross Posted May 3, 2012 Share Posted May 3, 2012 I htink the HCAD build date may be wrong. The first mention I can find for the house is in 1968, when Hill & White, Inc received a Deed of Trust from John and Pauline Mclaggan and gave them a Warranty Deed. There are a number of other transactions in Walnut Bend with Hill & White, so I suspect they might have been builders. I did not see any Butlers as owners, it' s pretty easy to get properties mixed up if you don't make sure you have the correct lot and block.As for a picture, good luck with that.I would love to have a picture of my house in the 50's, but haven't found one. Quote Link to comment Share on other sites More sharing options...
sevfiv Posted May 8, 2012 Share Posted May 8, 2012 ^Same here. Hill & White were developers (see here and here) and there was no listing for 10626 in the 1963 directory (it jumps from 10614 to 10630 on that side of the street).I did find the record for the probable 10614 builder (Fenway Co.) dating to 1962.. Quote Link to comment Share on other sites More sharing options...
Earlydays Posted May 11, 2012 Share Posted May 11, 2012 Here's an interesting websitehttp://showmystreet.com/to look at homes you've lived in..... Quote Link to comment Share on other sites More sharing options...
NenaE Posted May 11, 2012 Share Posted May 11, 2012 (edited) Ross, I agree, I've found HCAD to be wrong on a number of occasions.Earlydays, thanks for the link, interesting. I've found GoogleEarth doesn't work as well as it used to, for getting u close to a particular house, for viewing. This is good.Walnut Bend is an interesting area. My aunt had a beautiful home in that neighborhood.Some homes in the neighborhood were featured in the Parade of Homes. Edited May 11, 2012 by NenaE Quote Link to comment Share on other sites More sharing options...
