jm1fd Posted June 8, 2005 Share Posted June 8, 2005 I looked at a house today built in 1959 that had a solar "powered" A/C system. There was a big aluminum collector on top of the garage, and in the house there was a chilled water loop for cooling, and a boiler with a heated water loop for heating. After doing some research this sounds like an absorbtion type system....was this a popular thing to have back then, or was this the result of an engineer having built and owned the house? I could see why these might have been popular....supposedly these systems save tons of electricity. Link to comment Share on other sites More sharing options...
Subdude Posted June 9, 2005 Share Posted June 9, 2005 The roof-mounting makes this seem like the same kind that you see on houses in Arizona. I thought it had something to do with the climate. Link to comment Share on other sites More sharing options...
jm1fd Posted June 9, 2005 Author Share Posted June 9, 2005 The roof-mounting makes this seem like the same kind that you see on houses in Arizona. I thought it had something to do with the climate.<{POST_SNAPBACK}>You mean like an evaporative cooler? Those are quasi-popular in the desert where there's no humidity, and water will evaporate quite readily.I think this is an absorption based system where you use heat energy to draw heat out of something else. Link to comment Share on other sites More sharing options...
