MarthaG Posted January 31, 2008 Share Posted January 31, 2008 I need to hire a plumber... what is the going hourly rate for licensed master plumber these days? Link to comment Share on other sites More sharing options...
flipper Posted January 31, 2008 Share Posted January 31, 2008 I need to hire a plumber... what is the going hourly rate for licensed master plumber these days?This is not the answer to your question, but what do you need to have done?flipper Link to comment Share on other sites More sharing options...
MidtownCoog Posted January 31, 2008 Share Posted January 31, 2008 Also not your answer, but I always have heard avoid the hourly rate guys. Link to comment Share on other sites More sharing options...
AJXterra Posted January 31, 2008 Share Posted January 31, 2008 Also not your answer, but I always have heard avoid the hourly rate guys.Bid the job...not the hours... Link to comment Share on other sites More sharing options...
MarthaG Posted January 31, 2008 Author Share Posted January 31, 2008 I have one running tests to see what is wrong... there is some kind of leak in the shower area.. I am guessing I have to find out what exactly is wrong before I can bid by the job? Looks like I may need some tile work done as well... This guy charging $65 per hour to run these tests... sound fair? Link to comment Share on other sites More sharing options...
RedScare Posted January 31, 2008 Share Posted January 31, 2008 This guy charging $65 per hour to run these tests... sound fair?Yeah.I've heard as high as $90...few below $65. Link to comment Share on other sites More sharing options...
AJXterra Posted January 31, 2008 Share Posted January 31, 2008 I have one running tests to see what is wrong... there is some kind of leak in the shower area.. I am guessing I have to find out what exactly is wrong before I can bid by the job? Looks like I may need some tile work done as well... This guy charging $65 per hour to run these tests... sound fair? Yeah, you need to find out whats wrong...and by the sound of it you won't like the answer. Just have someone around making sure they're working the whole time while hourly and then bid the job when you know the problem. Good luck! Link to comment Share on other sites More sharing options...
MarthaG Posted January 31, 2008 Author Share Posted January 31, 2008 Thanks guys... I have noticed he has been on the phone a lot. We will discuss that when he tells me final price for today...So far... the test shows no leaks in any of the pipes..and my pressure is good. Today he is only caulking the shower fixture. I asked him to look at some other things "while he was here" so you know the bill is going up by the minute. The problem in the shower is definitely tile leaking... not good... There goes the tax return money...Can anyone recommend a tile person? Near the Heights area. Link to comment Share on other sites More sharing options...
cgallagher Posted February 12, 2008 Share Posted February 12, 2008 $65 is a reasonable price. The prettier the van that they pull up in, the more they cost. Does the problem only occur after someone uses the shower, or is it a constant drip? If it's only when someone uses the shower, the caulking will probably fix it. Otherwise, it may be more costly. Link to comment Share on other sites More sharing options...
