sevfiv Posted May 8, 2007 Share Posted May 8, 2007 is the community calendar closed for user-submitted entries now? Link to comment Share on other sites More sharing options...
tmariar Posted May 8, 2007 Share Posted May 8, 2007 is the community calendar closed for user-submitted entries now?I tried submitting something a week or two ago, and it didn't show up on the calendar. I don't know if that's the same problem you're having, sevfiv. It did let me fill out the form, just never showed up. I tried twice, with no luck, and I couldn't tell what I might be doing wrong. Link to comment Share on other sites More sharing options...
editor Posted May 8, 2007 Share Posted May 8, 2007 To prevent spam, calendar submissions have to be approved by a moderator or administrator. I try to remember to check for new entries every couple of days, but I often forget. Sorry. Link to comment Share on other sites More sharing options...
ArchitecturalPRGirl Posted May 8, 2007 Share Posted May 8, 2007 Yes I've tried to submit before and it didn't post. Link to comment Share on other sites More sharing options...
sevfiv Posted May 8, 2007 Author Share Posted May 8, 2007 i can't even get that far (to the form) Link to comment Share on other sites More sharing options...
tmariar Posted May 8, 2007 Share Posted May 8, 2007 To prevent spam, calendar submissions have to be approved by a moderator or administrator. I try to remember to check for new entries every couple of days, but I often forget. Sorry.That hadn't occurred to me - makes sense.Sevfiv - I just tried and couldn't get to the form either. Link to comment Share on other sites More sharing options...
editor Posted May 9, 2007 Share Posted May 9, 2007 That hadn't occurred to me - makes sense.Sevfiv - I just tried and couldn't get to the form either.Does it not display the option to add a new event, or are you not able to click on it? Link to comment Share on other sites More sharing options...
bachanon Posted May 9, 2007 Share Posted May 9, 2007 Does it not display the option to add a new event, or are you not able to click on it?i'm getting the "Sorry, but you do not have permission to use this feature. If you are not logged in, you may do so using the form below if available." message Link to comment Share on other sites More sharing options...
sevfiv Posted May 9, 2007 Author Share Posted May 9, 2007 ^ yep - that's the message Link to comment Share on other sites More sharing options...
houstonmacbro Posted May 9, 2007 Share Posted May 9, 2007 Seems like last time I tried, it wouldn't even give me the form. Link to comment Share on other sites More sharing options...
editor Posted May 11, 2007 Share Posted May 11, 2007 OK, try again. It should work now.I've also removed the moderator approval, so events you add should show up immediately. Link to comment Share on other sites More sharing options...
Pumapayam Posted May 11, 2007 Share Posted May 11, 2007 I've also removed the moderator approval Okay, cool, I will post more strip poker party event on their now! Link to comment Share on other sites More sharing options...
sevfiv Posted May 11, 2007 Author Share Posted May 11, 2007 thanks - works like a charm Link to comment Share on other sites More sharing options...
