Yankee_in_TX Posted October 13, 2009 Share Posted October 13, 2009 Running out of ideas. It's not the spark plug (I swapped it with a working burner), it's not the electric ignitor (it clicks), and it's not the gas line (I can light it with a match). Any ideas before I give in and call someone? We have a sealed type burner (kina' like this): Link to comment Share on other sites More sharing options...
musicman Posted October 13, 2009 Share Posted October 13, 2009 have you tried removing/reseating the center disk? sometimes if it is slightly off in alignment the burner won't light. Link to comment Share on other sites More sharing options...
Yankee_in_TX Posted October 13, 2009 Author Share Posted October 13, 2009 have you tried removing/reseating the center disk? sometimes if it is slightly off in alignment the burner won't light.Yes, I have had the whole thing apart and back together. Link to comment Share on other sites More sharing options...
BryanS Posted October 13, 2009 Share Posted October 13, 2009 No spark. The igniter may be clicking, but it may not be sparking. Like every igniter I have seen on a BBQ grill... you can push that button over and over and over... nothing. That's when you resort to just using matches.I would say faulty igniter... Link to comment Share on other sites More sharing options...
BryanS Posted October 25, 2009 Share Posted October 25, 2009 Has the problem been solved? We need to know. Link to comment Share on other sites More sharing options...
Yankee_in_TX Posted October 28, 2009 Author Share Posted October 28, 2009 Has the problem been solved? We need to know.Haven't tried to replace the starter yet. Will post after I do. It will be a little more difficult as I have yet to figure if the entire range top pulls up or not. Link to comment Share on other sites More sharing options...
Fringe Posted October 28, 2009 Share Posted October 28, 2009 I had a similar problem. The igniter was sparking but wasn't correctly aligned. Adjusted with some needle nose pliers and it's now working great. Link to comment Share on other sites More sharing options...
Yankee_in_TX Posted October 28, 2009 Author Share Posted October 28, 2009 I had a similar problem. The igniter was sparking but wasn't correctly aligned. Adjusted with some needle nose pliers and it's now working great. Awesome, I'll look for that. Link to comment Share on other sites More sharing options...
TJones Posted October 30, 2009 Share Posted October 30, 2009 Awesome, I'll look for that.Ummmmm, did anyone else hear and fell that BOOM !!! Link to comment Share on other sites More sharing options...
Yankee_in_TX Posted November 29, 2009 Author Share Posted November 29, 2009 I had a similar problem. The igniter was sparking but wasn't correctly aligned. Adjusted with some needle nose pliers and it's now working great. That was pretty much it. Once I found the starter device (the entire top didn't open, I had to remove all 4 burners and look in), one of the wires was actually not plugged into it It was a pain to get in there due to the angel, but we got it. Link to comment Share on other sites More sharing options...
