Bungalow Exterior
Good Afternoon All,
Any advice, comments, ideas, or experience for an older home with
cypress wood exterior walls . . . what type of paint and method is preferred or recommended ?
Should the exterior be painted by hand with a brush or by spray ? Why / Why not ?
Also the base color is white so should not need to be scraped if that is allowed ?
Thank You
Good Afternoon All,
Thank You
brush tends to put a thicker (longer lasting) coat on than spraying. but spraying is easier for the painters.
the base color has nothing to do with whether the house has to be scraped. the scraping is done to remove loose paint so that when you repaint you don't get bubbles or pieces than come off easily. there must be a secure surface for the paint to adhere to.
as for type of paint, just make sure than the coat you put on top is of the same type so it just doesn't peel right off. otherwise prims properly and you'll be ok.
Edited by musicman
Good Afternoon,
I am assuming painting an exterior wall of a home by hand brush is costly vs spray ?
What have you encountered for cost of bungalow home about 1,100 SQFT for 2 colors spray or by hand??
Thank You
your costs will vary depending on several factors. paint used, amounts needed to be scraped/sanded(very impt because if they do a lousy job, paint wont adhere), hand vs. spray is probably the biggest thing cause the hand painting takes way more time and or requires more labor so they charge more.
