Highrise Tower Posted July 22, 2023 Share Posted July 22, 2023 Noticed this old Loopnet listing recently. So that's what used to be located at the present (water retention ditch?) located to the right of the town home development. Pretty cool, you can still see the old entrance and gate into the business! Marcus Oil & Chemical Year Built: 1979 Building Size: 328,910 SF Property Type: Industrial Property Subtype: Distribution Warehouse Lot Size: 20.30 AC 328,910 square foot truck high tilt wall warehouse / office facility with 14 floating truck docks plus ramp to ground level on 20.3 acres including 5.3 acres undeveloped for expansion. Over 27,000 sq. ft. is insulated & climate controlled by 5 - 10 ton chillers. Also has 6 rail doors to 2 rail spurs 1100 feet in length. Support column spacing is 40 Ft. x 32 Ft. with minimum 24 Ft. clear overhead height. The entire facility is protected by a fire water sprinkler system. Includes a beautiful 2 story atrium office building with 234 designated parking spaces. This is in an ideal location on US Alternate 90 (11515 South Main Street) just off I-610 within site of the Astrodome in Houston with easy access to the Port of Houston. Property contains 20.3 acres fronted on US Alt 90 (South Main Street at Stella Link) with 5.3 acres on the north undeveloped as room for expansion. There is a detention pond eliminating any chance of flooding. This property also contains 2 rail spurs and switch that have all recently been rebuilt. https://www.loopnet.com/Listing/14022048/11515-South-Main-Street-Houston-TX/ A 2006 view of the Marcus Oil & Chemical complex. Current, 2023 view of the vacant land. Now a retention pond? Quote Link to comment Share on other sites More sharing options...
