Guest Marty Posted July 3, 2007 Share Posted July 3, 2007 (edited) A suspected secret cell of foreign militants, believed to be linked to al-Qa'ida and using British hospitals as cover, are being questioned over the terrorist attacks in London and Glasgow......Link to the story The Independent Edited July 3, 2007 by Marty Quote Link to comment Share on other sites More sharing options...
MidtownCoog Posted July 3, 2007 Share Posted July 3, 2007 go figure Quote Link to comment Share on other sites More sharing options...
TJones Posted July 3, 2007 Share Posted July 3, 2007 I heard some good stuff about the SUV fire at Glasgow. People, not experts mind you, wannabe experts it seems, were calling in to the radio shows saying thing like, " I don't understand why didn't they use the foam to quickly put out the fire, instead of using water, which took longer to put out the fire ? It looks like the British Govt. was showing those images to perpetuate the fear and worries of the British people." Well, a firefighter from Boots and Coots, called in and explained to the previous callers that," The only way to fight a gas fire is with water. You have to contain the propane bottles that had open valves going at full blast inside the SUV, and if you use foam to smother the fire that the gas is still leaking and has potential to blow up again, so you just keep pooring water on everything around the fire until it burns itself out. It was a controlled burn." Nobody ever called in after to refute it. Quote Link to comment Share on other sites More sharing options...
