jb4647 Posted April 9, 2007 Share Posted April 9, 2007 I'm moving into a condo at the end of the month and would like to turn a shelving area in the living room into a wet bar. Probably would like a mirror in the back and a light up top as well as a sink. Any suggestions on who could do a job like this and about what a ballpark figure it would cost? Here's a photo of what it looks like now: Quote Link to comment Share on other sites More sharing options...
musicman Posted April 9, 2007 Share Posted April 9, 2007 (edited) should be an interesting project. i hope you have a drain nearby already otherwise adding it will be expensive, particularly if you're on a slab (pier/beam would be easier). the light should be easily, if you have access to attic. otherwise the lighting could get hairy too. mirrors are easy Edited April 9, 2007 by musicman Quote Link to comment Share on other sites More sharing options...
flipper Posted April 10, 2007 Share Posted April 10, 2007 What's behind this area? Is this a 1 story?flipper Quote Link to comment Share on other sites More sharing options...
Pumapayam Posted April 10, 2007 Share Posted April 10, 2007 Make sure it is sturdy enough to handle someone strutting their stuff and add some support for dancing, maybe at a pole on one side. Quote Link to comment Share on other sites More sharing options...
jb4647 Posted April 10, 2007 Author Share Posted April 10, 2007 Just behind the bar wall is the guest bathroom so there is access to plumbing... Quote Link to comment Share on other sites More sharing options...
musicman Posted April 10, 2007 Share Posted April 10, 2007 Just behind the bar wall is the guest bathroom so there is access to plumbing...that's good news as long as a drain is on the wall immediately behind the proposed bar. if it is on another wall, it may not work so easily. as for cost, depends a lot on the materials you want to use. Quote Link to comment Share on other sites More sharing options...
