jdbaker Posted March 13, 2007 Share Posted March 13, 2007 I have a condo that is in need of a new central AC system. Currently, the compressor is located inside my condo. It's mounted in a sealed off closet-like space along an exterior wall. The hot air vents to the outdoors through a steel vent insert that was formerly a window opening. Suffice to say it's not an ideal setup. The plan is to move the compressor up to the roof, as several other owners have already done. I'm on the 6th floor, and the roof is approximately 24ft above my ceiling. There is a utility chase next to spot where my compressor is currently located, which runs all the way to the roof and should make it relatively painless to run the cooling lines and power for my unit to the roof. I'm hoping someone here might be able to recommend an HVAC person that could handle this job. Any suggestions? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
jm1fd Posted March 14, 2007 Share Posted March 14, 2007 I've heard that Central City Air is rather good, although expensive. I used Stom's A/C http://www.cleartheairac.com/ (they changed their name) for my house they were OK, but the price was good, and the warranty was excellent. Quote Link to comment Share on other sites More sharing options...
mpbro Posted March 14, 2007 Share Posted March 14, 2007 Have used Debowski in the past for home AC repairs, and they are reasonably priced and pragmatic, but cannot make recs for a HVAC project, sorry... Quote Link to comment Share on other sites More sharing options...
lwood Posted March 14, 2007 Share Posted March 14, 2007 I have a condo that is in need of a new central AC system. Currently, the compressor is located inside my condo. It's mounted in a sealed off closet-like space along an exterior wall. The hot air vents to the outdoors through a steel vent insert that was formerly a window opening. Suffice to say it's not an ideal setup. The plan is to move the compressor up to the roof, as several other owners have already done. I'm on the 6th floor, and the roof is approximately 24ft above my ceiling. There is a utility chase next to spot where my compressor is currently located, which runs all the way to the roof and should make it relatively painless to run the cooling lines and power for my unit to the roof. I'm hoping someone here might be able to recommend an HVAC person that could handle this job. Any suggestions? Thanks in advance.Central City Air. Quote Link to comment Share on other sites More sharing options...
