goodness Posted July 20, 2006 Share Posted July 20, 2006 I was filling up a form online. While I'm trying to send my certificate, I get a message says"It must be DOC or PDF"I don't know what to do. It took me two days now. Quote Link to comment Share on other sites More sharing options...
goodness Posted July 20, 2006 Author Share Posted July 20, 2006 by the wayi did download ADOBE. and I saved my certificates as PDF but the problem is that there are two certificates that should be sent at the same time. I couldn't put them together in the same PDF Quote Link to comment Share on other sites More sharing options...
Pumapayam Posted July 21, 2006 Share Posted July 21, 2006 create a MSWord document that contains both certificates and then send it to Adobe.either way, (2) .pdf attachments is not a big deal, is it?you can attach more than one file in an email, or just send (2) emails. Quote Link to comment Share on other sites More sharing options...
travelguy_73 Posted July 21, 2006 Share Posted July 21, 2006 by the wayi did download ADOBE. and I saved my certificates as PDF but the problem is that there are two certificates that should be sent at the same time. I couldn't put them together in the same PDFWhen you create a PDF in Adobe, you can insert one PDF into another. Open up the first one, and then choose Insert, then just scroll through the options...it's easy! Quote Link to comment Share on other sites More sharing options...
MajorD Posted July 24, 2006 Share Posted July 24, 2006 I suggest downloading and installing PDF Creator. Its software that acts like a printer. The only output though is pdf files. Any type of document you throw at it such as xls, doc, etc will be converted to a saveable pdf file.here is the link.http://sourceforge.net/projects/pdfcreator/ Quote Link to comment Share on other sites More sharing options...
goodness Posted August 1, 2006 Author Share Posted August 1, 2006 Thank you very much guys for helping me. I'll re-install it again and try to use it. I had to split my certificates into 2 emails. I hope they would accept them Quote Link to comment Share on other sites More sharing options...
