NThomas Posted May 27, 2009 Share Posted May 27, 2009 I'm working on a design for a "loft" condo. I need to fit the following stuff form a bathroom in a small space and I can't rack my brain anymore. Washer Dryer Countertop sink Toilet Bath Closet (Reach-in) Have any ideas? Please post! Link to comment Share on other sites More sharing options...
strickn Posted June 8, 2009 Share Posted June 8, 2009 Try putting a top-loading washer, sink, and dryer down the right-hand wall (as you walk in; on the left in plan), so that you'll have a workspace to use [medicine cabinet behind the fold-down ironing board?] and one that will be available even when the tub or toilet are in use. You could either have a closet in the jog of the wall behind - and another door in line with the first to lead to the inner bathroom - or you could altogether avoid the expense of framing in another door as follows. Let the jog contain two of the three feet of a 3' wide passage, curtained as creatively as you like, parallel to the main door, and divide the rest of the space with a 5'6" storage divider running parallel to the main door (and not necessarily all the way to the ceiling - more lively if you won't). There should be enough room behind it for the tub and toilet cul-de-sac that you could have a bit of shelving facing back there for their toiletries too. In any case you will have to port the dryer and the bathroom humidity out-of-doors if there is no window. By the way, that galley kitchen is not likely going to work smoothly, if there's anything you can look to do about that. Link to comment Share on other sites More sharing options...
