jscarbor Posted March 1, 2009 Share Posted March 1, 2009 My water heater pan has standing water in it. Is there a common problem regarding this that can be fixed? Quote Link to comment Share on other sites More sharing options...
BryanS Posted March 1, 2009 Share Posted March 1, 2009 No. Cannot be fixed. Your water heater is failing. You might be surprised to find 40 gallons of hot water on your floor... when you're not there.Replace the water heater, ASAP....or maybe there is a lose water feed connection... check that... but sounds like you need to replace it. ASAP. Quote Link to comment Share on other sites More sharing options...
flipper Posted March 1, 2009 Share Posted March 1, 2009 My water heater pan has standing water in it. Is there a common problem regarding this that can be fixed?Is there a hose coming out of the pan? How old is the water heater?flipper Quote Link to comment Share on other sites More sharing options...
jscarbor Posted March 1, 2009 Author Share Posted March 1, 2009 Its a 1998 tank.It looks like a small amount of water is coming from the top of the unit at the what I believe to be the pressure relief valve. Quote Link to comment Share on other sites More sharing options...
rbarz Posted March 1, 2009 Share Posted March 1, 2009 Its a 1998 tank.It looks like a small amount of water is coming from the top of the unit at the what I believe to be the pressure relief valve.Is the area it is leaking from corroded? Quote Link to comment Share on other sites More sharing options...
BryanS Posted March 1, 2009 Share Posted March 1, 2009 Replace it. Quote Link to comment Share on other sites More sharing options...
jscarbor Posted March 1, 2009 Author Share Posted March 1, 2009 Yeah, it was corroded. I am going to replace. Ouch. Quote Link to comment Share on other sites More sharing options...
flipper Posted March 2, 2009 Share Posted March 2, 2009 piece of cake. pick up some new 18" or 24" copper water flex lines to make your life easy. don't put the old WH at the curb unless you want to take a chance at the COH getting involved.flipper Quote Link to comment Share on other sites More sharing options...
jscarbor Posted March 2, 2009 Author Share Posted March 2, 2009 new water heater. It wasn't the PRV...we cleaned it up and felt insulation and that is where it is leaking...inside the tank. Quote Link to comment Share on other sites More sharing options...
