jc281 Posted May 13, 2008 Share Posted May 13, 2008 Saw this mentioned. Basically its like the old terrazzo floor, but no concrete just epoxy? stronger and really shiny.if anyone has experience/familiarity with this, I'm just trying to gauge its cost vs. tileIts for 2 small rooms, ~600 sq ft. the main concern is a growing crack in the foundation....over time it will break the grout and tile if its laid on top. Initial thought is this terrazzo could be stronger and pretty stylish. Link to comment Share on other sites More sharing options...
rbarz Posted May 13, 2008 Share Posted May 13, 2008 considerably more expensive than tile... it is like custom artwork. It is at least 10x more than tile. Link to comment Share on other sites More sharing options...
jc281 Posted May 13, 2008 Author Share Posted May 13, 2008 ugh. was expecting 2 or 3xanyone know anyone that specializes in it ? Link to comment Share on other sites More sharing options...
Justin2002 Posted May 16, 2008 Share Posted May 16, 2008 Have you looked at using tile and installing a decoupling membrane between the slab and tile? Schluter makes an excellent product called Ditra that is perfect your application. More info can be found at the link below.http://www.schluter.com/6_1_ditra.aspxFrom the website:Tile has been successfully installed for thousands of years by incorporating an uncoupling layer, or forgiving shear interface, within the tile assembly. Schluter-DITRA provides uncoupling through its open rib structure, which allows for in-plane movement that effectively neutralizes the differential movement stresses between the substrate and the tile, thus eliminating the major cause of cracking and delaminating of the tiled surface. Link to comment Share on other sites More sharing options...
rps324 Posted May 16, 2008 Share Posted May 16, 2008 I was in a house in Glenbrook this week that a couple from Clear Lake are restoring. They had a section of poured terrazzo put in and the "divets" from where it had carpet tack strips repaired. I thought it would be cost prohibitive to have any new portion done. It is NOT terrazzo tile but the regular poured kind. But apparently it wasn't that bad to have done by this one person. John Calarco (sp?) did it. His info is on this forum somewhere if you search terrazzo. Link to comment Share on other sites More sharing options...
