Posted
Hi. I'm needing to get some foundation repair done and was wanting comments (pro or con) regarding the Cable-Lock system. I was thinking of using Atlas Foundation for the job. Other candidate would be Du-West, but they use a different system.
Thanks,
Jeff
Posted
the problem isn't what type of system they use but rather whether they have a structural engineer to determine the exact problem and where the fix needs to be done, if needed.
Posted
Hi. I'm needing to get some foundation repair done and was wanting comments (pro or con) regarding the Cable-Lock system. I was thinking of using Atlas Foundation for the job. Other candidate would be Du-West, but they use a different system.Thanks,Jeff
I think the cable lock system is a joke. Ok, maybe not a joke, but not necessary. I refuse to pay a company like Atlas to hire Nolan Ryan to do commercials for them. Give me a company with a small, long time employed crew that doesn't cut corners any day.If it were me, I'd toss out the phone book and talk to some realtors in your area for a referral.flipper
Problem with that is you can have 5 engineers come out and give you 5 different "solutions".flipper
Posted
yep and there are multiple solutions to some problems.
Posted
I think the cable lock system is a joke. Ok, maybe not a joke, but not necessary. I refuse to pay a company like Atlas to hire Nolan Ryan to do commercials for them. Give me a company with a small, long time employed crew that doesn't cut corners any day.If it were me, I'd toss out the phone book and talk to some realtors in your area for a referral.flipperProblem with that is you can have 5 engineers come out and give you 5 different "solutions".flipper
Thanks for the comments. I did have an independent engineer come out and as a result probably will only do one section even though the foundation companies said, as I figured they would, that I need more.
I'd forgotten that Ryan had done commercials for them, but that aside, I thought they were considered to be reputable, but maybe not. Olshan uses the same system, but I thought Atlas may be was a little better. Just a gut feeling, I guess. I may look a little closer at DU-West and also try your recommendation of checking with realtors.
Jeff
