The RO: Mixed-Use Development At West Alabama And Buffalo Spdwy.
YakuzaIce
19 minutes ago, Highrise Tower said:
Parts of the site have low levels of contaminated groundwater. A Municipal Settings Designations (MSD) application was sent to the city.
https://www.houstontx.gov/council/committees/rna/20190117/msd.pdf
https://www.tceq.texas.gov/remediation/msd-certificate
That's interesting. This could be why they haven't been able to start yet. Especially with what they are proposing (office/retail/residential mixed-use), contaminated ground water is actually a real problem. I'm also wondering if this is partly why its taken East River some time to really kick off as well. Old industrial sites, depending on what they were used for can be a challenge to clean up and prep for uses where people will actually live on the property. My knowledge is limited on this however, so someone who is well versed in this particular area please chime in. This isn't a death nail for the project or anything, but simply one that can slow it down. If this is the what they were told then they will have to do remediation of the site before they can begin construction. Unsure to what extent, and how that can be done. What I will say is that this could actually later on be flipped as a positive for the development if its able to kick off. The positive being that they could go the full LEED route, and get a lot of positive publicity for their remediation efforts, and improving the property/quality of life for the area.
I’m surprised and also not surprised this popped up. Through the 90s and prior, before they built the Exxon Training Center, this corner was a Full Service Gas Station with Service Center and Convenience Store.
The Exxon Gas Station had Underground Storage Tanks that leaked. Next door it was apparent because the storm water coming into the storm sewer sump at the second sub basement, would smell like gas. A system was installed to filter this out and the water was directed to the sanitation sewer.
This system was removed several years ago, but you could still smell the gas odor. Apparently it was under the threshold of being a hazard after the last inspection by Environmental Services. After Harvey, there was so much water that almost all the lingering smells were washed away and seems like this wasn’t going to be an issue anymore, presuming this is what was found.
The next  issue I think they may encounter is an underground spring below the property. We get groundwater coming in non-stop into our sump. It can be 6 months of drought and the water still continues. Being that it picked up the gasoline concentration it is theory that it runs under the former Exxon property before us. It will be interesting to see if underground water causes issues when they dig out the foundation, and if the stream coming in our sump diminishes after construction.
Kudos to them for the voluntary clean up of what remains.
  • Like 5
  • Thanks 4
It doesn't look that bright to me...
Either way, this is a rendering, and doesn't necessarily reflect how real sunlight will interact with real materials. I strongly doubt they're planning perfect white tiles with high reflectively.
Of course I could be wrong, but I imagine after the third or so person spontaneously bursts into flames walking across them, they will be replaced.
  • Like 4
  • Haha 4
Speaking from experience with rendering. This is a reflectivity setting being set too high. Pavers, even white ones, aren't that reflective. Sometimes a render engine will make even things which aren't that reflective or glossy a lot more reflective or glossy than what they really are. Actually I was kinda put back by @Montrose1100 comment, but then I was like, "ok wait a second, I know clients that make the exact same statements even though its a render because they want to make sure what they are getting is what they are getting." So after taking a step back, and reflecting on it, I could understand why Montrose1100 would say that, and he does have a point. In this image it is way to reflective. I would say its probably not going to be that reflective in real life. I could be wrong. I have been before, but the only time you get a paver/brick that is that reflective is if its a glazed brick which you don't really ever put on the ground. Occum's Razor would suggest that its a flaw in the actual rendering of the material, and not a reflection of what it will actually be. It happens. I don't think its bright, but I can see why Montrose1100 says its bright, and its a comment to keep in mind. If he thinks that there might be others that think that as well.
Edited by Luminare
  • Like 6
Aside from small activity (utility work, generators getting fueled up, desks and furniture moving into the trailers) not much has happened (Yet).
Re-examining the groundwater impacts a few posts back; the areas marked would be the Phase 2 section of the project. The old gas station sat on where Phase 1 is going. If this was the cause of contamination it migrated south. I'm unsure if they would address this first, or go ahead and begin removing trees, busting up the old Exxon Training Center and parking lot concrete and begin setting footings for the new buildings.
Also Buffalo Speedway from West Alabama going North is undergoing the start of a Capital Project to replace wastewater facilities. Crews have been out this past week setting up, and big machinery is out ready to dig. The plan I heard, is to tunnel under the street to do the work without disturbing the esplanades and most of the trees that sit on them. The project will take 16 months to complete.
https://www.publicworks.houstontx.gov/sites/default/files/assets/001-project_Information_notice_r-000035-0012-4.pdf
https://www.publicworks.houstontx.gov/sites/default/files/assets/construction_phasing_map.pdf
Source with more informative PDFs:
https://www.publicworks.houstontx.gov/node/342
Furthermore, The project to improve West Alabama is still alive. The Upper Kirby info I've found for Buffalo Speedway - Shepherd is outdated, but hopefully there will be a new timeline. Eventually this Alabama Street improvement will go all the way east to Almeda.
Quote
As part of a bigger four-phase effort, the Houston has been responsible for two segments of improvements to West Alabama.
The Weslayan Street to Buffalo Speedway segment is scheduled for construction in 2021 and calls for new concrete streets with storm drainage, sidewalks, driveways, street lighting with water and wastewater updates. The project is scheduled for bids later this month. Construction is slated for spring 2021.
The segment from Buffalo Speedway to Shepherd is the responsibility of the Upper Kirby TIRZ, while the segment from Spur 527 to Chenevert is the responsibility of the Midtown TIRZ.
Timeline: spring 2021-TBD
Cost: $15.87 million
Source:
https://communityimpact.com/houston/heights-river-oaks-montrose/transportation/2020/07/07/improvements-are-coming-to-west-alabama-street-in-river-oaks-area-in-2021/
This intersection is going to look very different in just a few years.
Edit:
I rechecked the Upper Kirby District site and the West Alabama reconstruction from Buffalo Speedway to Shepherd is listed to happen in 2021/2022 for $22 Million.
http://www.upperkirbydistrict.org/index.php/the-district-at-work/district-projects/coming-soon
Edited by Geoff8201
Updated Information
  • Like 5
  • Thanks 1
Thanks, good info. I wondered what they were doing to Buffalo Speedway. Guess we have a year of const to look forward to. Then years of R.O. const 🙃
It will be nice to get Alabama updated.
I noticed on the Upper Kirby project map, they show Richmond (inside B.S.) to be complete. But it's not, it's still ripped up and scraped down, but no overlay yet.
It's funny (actually, it's not), when they started scraping all the years of overlays from Richmond earlier this year, I thought "Great timing, there's no traffic on Richmond due to shutdown, what a perfect time to repave that street". So they scraped it from Kirby to Timmons several months ago, and... {crickets chirping} ...they have not done one single thing since.
Four months of the least traffic we will EVER see in Greenway Plaza, and it sits there untouched. Not one minute of work (that I can detect) in four months.
  • Like 5
  • Sad 1
  • 4 weeks later...
19 hours ago, mls1202 said:
Apologies if this has been already covered, but what (if anything) is happening to the empty land north of RO? From Google Maps, it shows what looks like overflow parking for St. John, but I have to imagine this land is going to be super-valuable...
All the land to the north of The RO lot up to The River Oaks Condo Building belongs to St. John’s. There is a giant multi use field, parking garage, and temporary buildings with a parking lot the Urban Harvest Farmers Market currently uses on Saturday mornings.
It is my understanding that eventually this will become new buildings and athletic facilities for the school.
17 minutes ago, samagon said:
right? we deserve less!
I don't mean that in a bad way it just seems like most designs in Houston are safe. I personally would love more interesting and bold designs.  Honestly I don't see why this isn't already the case with our mishmash neighborhoods, "no zoning", and lack of city wide NIMBYs.
  • Like 5
I absolutely agree, I love traveling to Europe, not just to see the history in the place, but the edgy architecture is fun to look at.
I'm hopeful this comes through, and we get more stuff like this.
  • Like 8
  • 1 month later...
For a project that was originally “Coming in 2019” and hasn’t even shown signs of breaking ground now at the end of 2020, no it doesn’t look good. But.... it is 2020, which has not been the best year for anyone.
It’s disappointing to hear about the office listings being pulled and the trailers being used for the sewer project... oh which btw I observed the very first trailer on the west end of the lot was actually being used for the Christian Community Service Center construction a block over. Saw people going back and forth and then the  light bulb went off that this trailer has nothing to do with the RO either.
I still feel this project would do very well, with exception to the office building portion, based on how things are right now.
I hope this doesn’t go the way of River Oaks District which had three towers in the first rendering and got built as a midrise, granted it was a huge improvement form what existed before.
Hopefully whatever gets value re-engineered, or changed, or whatever is a huge improvement from what was there before and currently. Right now it’s a big dark lot at night, and it’s attracting homeless people.
20 hours ago, Geoff8201 said:
actually being used for the Christian Community Service Center construction a block over. <snip>
The CCSC is now open. I wish they had put some windows on the North wall. It's just one giant "wall". Bor-ing.
Homeless people? I need to look closer, I haven't seen any. Maybe you just saw me wandering around in my "work from home" outfit... loose fit sweats, baggy tee, "no haircut in nine months" look. 🙃
  • Haha 1
  • 4 weeks later...
So there is some activity, but I believe it has to do with groundwater cleanup....
They are digging towards the south end of the property. A notice went out to residents nearby indicating a Microsoft Teams meeting in the near future concerning groundwater contamination.
Correction, the groundwater cleanup online meeting I was referring to is for 3509 Texas Street.
The digging goes and is progressing slowly. I’ll post a photo from atop the Lamar Tower when it looks more progressed. Feel like I’ve posted enough pics of an empty lot for now. Highrises’s photos nailed it.
Edited by Geoff8201
Heard through the grapevine not to expect anything happening here all through 2021. A big scale back may happen cutting the building heights in half, or potentially combining their functions and cutting the number of buildings down. But in the age of Covid, for a giant site that was going to house restaurants, a hotel and an office building, is anyone surprised.
I personally hope the wait and see method pays off, and post covid the demand for everything comes roaring back.
Edited by Geoff8201
Grammar edits
  • Sad 5
  • The title was changed to The RO: Mixed-Use Development At West Alabama And Buffalo Speedway
  • 2 months later...
Site is dead. I don't see any heavy equipment, no activity, nothing has changed in months. I look down on this, and use my binocs to search for signs of life. There's more activity on Mars than The RO.
  • Haha 2
  • Confused 1
  • Sad 1
  • The title was changed to Land On Kirby Dr.
