job-op1 Posted March 24, 2006 Share Posted March 24, 2006 Here are the three job descriptions:Job 1:Commercial design/build firm seeks intern architect to join growing staff. Must be proficient in AutoCAD and Adobe Photoshop. Must have or be receiving an accredited architecture degree this May. Work experience a plus. Fax resumes to 713-465-8555. Please do not send portfolios or work samples via fax. If called for an interview, you will be able to present your portfolio then. Indicate that you are applying for the intern architect position on the cover page of your fax.Job 2:Commercial design/ build firm seeks AutoCAD tech/3D VIZ/AccuRender tech for preparing marketing presentations in fast-paced environment. Must be proficient in AutoCAD, AccuRender/VIZ, and Adobe Photoshop. Fax resumes to 713-465-8555. Please do not send portfolios or work samples via fax. If called for an interview, you will be able to present your portfolio then. Indicate that you are applying for the AutoCAD tech position on the cover page of your fax.Job 3:Commercial design/build firm seeks a project architect to join growing staff. Must be proficient in AutoCAD and Adobe Photoshop. Must have an accredited architecture degree and be pursuing licensure, if not already licensed. EXTENSIVE experience in commercial design a must. Fax resumes to 713-465-8555. Please do not send portfolios or work samples via fax. If called for an interview, you will be able to present your portfolio then. Indicate that you are applying for the project architect position on the cover page of your fax.If you have any questions etc. please list them on the cover page to your fax. Thanks and good luck!!! Link to comment Share on other sites More sharing options...
Please sign in to comment
You will be able to leave a comment after signing in
Sign In Now
