Rice University South Annex: Library Service Center & Data Center
https://scholarship.rice.edu/handle/1911/71846
Quote
The Rice University Data Center building, next to the Library Service Center.
Rice owns a lot of land off the Highway 90 feeder.  I went on a new running route and stopped by.  Looks like dirt is being moved at the back of the property. Expansion or maintenance related?
Link to post
Rice Data Center, Houston, TX (2006-2007)
https://carlosjimenezstudio.com/rice-university-data-center
Quote
The Rice Data Center (RDC) is a 25,400 sq. ft. data center that consolidates all of Rice’s data needs into one primary facility. The highly secured and protected environment is meant to guarantee a constant 24 hour run for the University’s data networks. It provides server floors, mechanical infrastructure, support spaces, and shell space for future expansion. The primary exterior material for the two buildings is a customized tilt-up concrete wall system designed to give each building’s envelope a protective and distinct opacity. The varied cascading pattern and profile of the concrete panels animates while scaling down each building’s large windowless mass. Painted a bright fluorescent green, the building acquires the presence of a geometric topiary across a vast green field.
Link to post
  • Highrise Tower changed the title to Rice University South Annex: Library Service Center & Data Center
Rice Library Service Center, Houston, TX (2002-2005)
https://carlosjimenezstudio.com/rice-university-library-service-center
Quote
The Rice Library Service Center (RLSC) is a high-density book storage facility with an anticipated capacity of 1.75 to 2.0 million volumes. The off-site 18,500 sq. ft. book depository improves and expands Rice University's Fondren Library by providing ample storage, as well as newer and more efficient filing and archiving systems. The facility consists of two distinct parts: a two-story office and processing area, and a three-story open volume - the book storage vault - containing rows of high-density modular shelving. The entire vault is a carefully controlled environment for storing lesser-used and fragile materials. A constant 50 degrees (Farenheit) and 30 percent humidity is maintained all year round—an ideal temperature for the long-term preservation of paper products as well as for film based-materials (microfilm, videotapes, slides, etc.). The building's primary exterior material is a customized tilt-up concrete wall system designed to provide a protective yet animated opacity. The wall's cascading profile animates and scales down what is primarily a windowless mass. Sealed and painted a bright, earthy green, the building acquires the presence of a geometric topiary across a vast green field.
  • Like 4
Link to post
  • 1 month later...
