H-Town Man Posted May 27, 2020 Share Posted May 27, 2020 14 minutes ago, Houston19514 said: FWIW, the area designated as downtown by the linked Brookings study (roughly speaking, the CBD, Midtown, and Eado) had almost 41,000 people in the 2010 census. I would venture to guess we are over 50,000 by now. Well, they didn't exactly spend a whole day in downtown Chicago either. For example, you can't watch a baseball game in downtown Chicago. I was comparing the size of their area in Chicago with a similar size in Houston. When they measured Houston, they used a somewhat wider geographical area that pulled in a lot of East End neighborhoods that go beyond what I'd call "Eado." But if you look at their map of what they're calling "downtown Chicago," it's about 1.7 miles x 2.9 miles, which is big enough to cover Downtown, Midtown, and Eado proper in Houston. Interestingly, for downtown Chicago they did not include Streeterville, the Gold Coast, or even North Michigan beyond roughly Chicago Avenue, so the population with all that is probably 150-200k. But then for Houston you'd have to add in Fourth Ward, Old Sixth Ward, and First Ward, and then maybe you're getting close to 50,000. That's true, their day wasn't spent strictly in downtown Chicago. And for our Houston Ferris, I would let him go to the Museum District. 2 Quote Link to comment Share on other sites More sharing options...
Houston19514 Posted May 27, 2020 Share Posted May 27, 2020 (edited) 49 minutes ago, H-Town Man said: I was comparing the size of their area in Chicago with a similar size in Houston. When they measured Houston, they used a somewhat wider geographical area that pulled in a lot of East End neighborhoods that go beyond what I'd call "Eado." But if you look at their map of what they're calling "downtown Chicago," it's about 1.7 miles x 2.9 miles, which is big enough to cover Downtown, Midtown, and Eado proper in Houston. Interestingly, for downtown Chicago they did not include Streeterville, the Gold Coast, or even North Michigan beyond roughly Chicago Avenue, so the population with all that is probably 150-200k. But then for Houston you'd have to add in Fourth Ward, Old Sixth Ward, and First Ward, and then maybe you're getting close to 50,000. That's true, their day wasn't spent strictly in downtown Chicago. And for our Houston Ferris, I would let him go to the Museum District. I used the downtown definitions used in the Brooking study. If we are going to use the Brookings definition for downtown Chicago, it only makes sense to compare it to the Brookings definition, using the same criteria, for downtown Houston. FWIW, I too noticed that Streeterville and the Gold Coast and part of North Michigan Ave were not included. I didn't dive deep into their methodology, but I presume there was good reason for that. I rather prefer the delineations used in the DefiningDowntown maps. Total for Chicago in this definition (which includes Streeterville, the Gold Coast and all of North Michigan Ave), is 144,000. Houston's is 58,500. Edited May 27, 2020 by Houston19514 2 Quote Link to comment Share on other sites More sharing options...
H-Town Man Posted May 27, 2020 Share Posted May 27, 2020 (edited) 20 minutes ago, Houston19514 said: I used the downtown definitions used in the Brooking study. If we are going to use the Brookings definition for downtown Chicago, it only makes sense to compare it to the Brookings definition, using the same criteria, for downtown Houston. I would disagree. Their definition for downtown Chicago includes somewhat less than most people consider to be the downtown Chicago area (Water Tower and John Hancock Center aren't even included). Their definition for downtown Houston is not only a much larger area geographically but includes neighborhoods that no one would consider part of downtown Houston, including large portions of Fifth Ward and Third Ward. The context of the discussion is how a residential population contributes to success and vitality of a downtown area; the forest of condo towers around Water Tower certainly contribute to downtown Chicago's success, Fifth Ward and Third Ward not so much. Edited May 27, 2020 by H-Town Man Quote Link to comment Share on other sites More sharing options...
Houston19514 Posted May 27, 2020 Share Posted May 27, 2020 2 minutes ago, H-Town Man said: I would disagree. Their definition for downtown Chicago includes somewhat less than most people consider to be the downtown Chicago area (Water Tower and John Hancock Center aren't even included). Their definition for downtown Houston is not only a much larger area geographically but includes neighborhoods that no one would consider part of downtown Houston, out along Navigation. The context of the discussion is how a residential population contributes to success and vitality of a downtown area; the forest of condo towers around Water Tower certainly contribute to downtown Chicago's success, neighborhoods of detached homes along Navigation not so much. Your argument is with Brookings (whose study you introduced to this conversation). They applied objective criteria to both cities and those are the results. Quote Link to comment Share on other sites More sharing options...
H-Town Man Posted May 27, 2020 Share Posted May 27, 2020 Just now, Houston19514 said: Your argument is with Brookings (whose study you introduced to this conversation). They applied objective criteria to both cities and those are the results. I am using a select part of the Brookings study which is not subject to the errors I mentioned in my last post. I am comparing apples to apples - the population of the section they showed in downtown Chicago in 1982 and the population in that same section of Chicago today. You are trying to make comparisons between what they chose as downtown Chicago and what they chose as downtown Houston, despite the obvious errors in such a comparison. People living in Third Ward and Fifth Ward are not a useful component of the population of downtown Houston for the purposes of discussing street life or tourism potential, whereas in Chicago, they actually left out populations that obviously contribute to downtown Chicago's vitality (e.g. the forest of condos around the water tower). It would be like me forcing you to accept any statement ever made on the Bob Newhart Show, just because the Bob Newhart Show was your source for understanding the downtown Chicago population in the 1980's. 3 Quote Link to comment Share on other sites More sharing options...
Nate99 Posted November 17, 2020 Share Posted November 17, 2020 Any other rumblings here? Along with the Hess garage block residential, this project would round out Discovery Green's adjacent blocks, I think. . 4 Quote Link to comment Share on other sites More sharing options...
Popular Post Highrise Tower Posted January 8, 2021 Popular Post Share Posted January 8, 2021 28 story office for Block 250. 29 Quote Link to comment Share on other sites More sharing options...
kbates2 Posted January 8, 2021 Share Posted January 8, 2021 Sounds like this is the big time news. That is awesome. This will help to mitigate the look of the Embassy Suites from Disco Green. 6 Quote Link to comment Share on other sites More sharing options...
H-Town Man Posted January 8, 2021 Share Posted January 8, 2021 This is incredible. Paging Paco Jones... 2 Quote Link to comment Share on other sites More sharing options...
thatguysly Posted January 8, 2021 Share Posted January 8, 2021 Great start to filling in this side of downtown. 4 Quote Link to comment Share on other sites More sharing options...
downtownian Posted January 8, 2021 Share Posted January 8, 2021 It's great news but hard to wrap my head around it in this context: "Almost 51 million square feet of office space – the equivalent of 50 downtown skyscrapers – is currently vacant in Houston." “Houston’s office market was struggling amid a glut of available space even before the outbreak of the deadly COVID-19 coronavirus,” said Wade Bowlin, president of property services, central division of Madison Marquette. And then there could be post-pandemic headwinds of additional working from home reducing the need for space and M&A and consolidation in energy. https://realtynewsreport.com/houston-office-vacancy-hits-highest-point-since-1980s-madison-marquette/ 5 1 1 Quote Link to comment Share on other sites More sharing options...
thatguysly Posted January 8, 2021 Share Posted January 8, 2021 Is it because some companies are willing to pay a premium for new office space that is LEED certified, as high end and new amenities, and other incentives that help with hiring a workforce? I can see the older buildings that are all outdated being hard to lease up. I always wonder what will happen to all the old brown and white Soviet looking building from the 70s around town. Some will dump money to renovate the inside but a lot of just bad. I have worked in a couple older buildings and they just don't feel like a successful company works there. Obviously, remote working and moving to campuses is changing how offices are leased up as well. 8 Quote Link to comment Share on other sites More sharing options...
Popular Post CREguy13 Posted January 8, 2021 Popular Post Share Posted January 8, 2021 2 hours ago, Highrise Tower said: 28 story office for Block 250. Happy to see this. The announcement of the lead tenant will be in the next week or so from what I'm told and I think this group will appreciate the renderings. This project does a nice job of closing out Discovery Green (along with Block 98) and completely hiding/wrapping around the Embassy Suites when standing at the park. 19 Quote Link to comment Share on other sites More sharing options...
zaphod Posted January 8, 2021 Share Posted January 8, 2021 I don't care that much if this project cannibalizes nameless suburban office buildings but it would be a shame if we had more vacancy in downtown and other major locales. 5 Quote Link to comment Share on other sites More sharing options...
downtownian Posted January 8, 2021 Share Posted January 8, 2021 47 minutes ago, zaphod said: I don't care that much if this project cannibalizes nameless suburban office buildings but it would be a shame if we had more vacancy in downtown and other major locales. Here's hoping the lead tenant will be a relocation from outside of downtown 8 Quote Link to comment Share on other sites More sharing options...
jmitch94 Posted January 8, 2021 Share Posted January 8, 2021 (edited) Anecdotally I’ve seen a lot of old small office spaces outside of major office market areas being torn down and replaced with retail or other more modern and useful development. Honestly would love for that to happen more. I’d rather lose 100 of those small outdated office blocks than one tower downtown. Edited January 8, 2021 by jmitch94 5 Quote Link to comment Share on other sites More sharing options...
phillip_white Posted January 8, 2021 Share Posted January 8, 2021 1 hour ago, downtownian said: It's great news but hard to wrap my head around it in this context: "Almost 51 million square feet of office space – the equivalent of 50 downtown skyscrapers – is currently vacant in Houston." “Houston’s office market was struggling amid a glut of available space even before the outbreak of the deadly COVID-19 coronavirus,” said Wade Bowlin, president of property services, central division of Madison Marquette. And then there could be post-pandemic headwinds of additional working from home reducing the need for space and M&A and consolidation in energy. https://realtynewsreport.com/houston-office-vacancy-hits-highest-point-since-1980s-madison-marquette/ Maybe the additional competition might push some of those vacant buildings to consider converting a portion to residential? 2 Quote Link to comment Share on other sites More sharing options...
tangledwoods Posted January 8, 2021 Share Posted January 8, 2021 Quote Maybe the additional competition might push some of those vacant buildings to consider converting a portion to residential? office buildings are VERY had to convert to residential. The floor to floor heights suck and you perimeter to core depths make it very tricky to get enough daylight into the residences. If i had a crystal ball, i would say that Skanska, Hines, Transwestern, etc. will continue to develop new trophy buildings for major tenants moving into the CBD or other prime areas. I think a lot of the small office buildings scattered through the inner loop are going to be demolished in the next 10 years as the demand for in town living continues to grow. Look at some of the low rise office buildings in upper kirby, or galleria that stuff is PRIME for residential and most of those spaces are class b or c at best. I do think we will see plenty of low rise new office space but it will have to be incorporated into mixed use projects. I bet we see plenty of GFR + 4 stories office or residential type projects moving forward. The brokers are all going to try and pretend that COVID didnt upend the commercial real estate market but I think the biggest winners from this shift in demand will be demolition companies, BRING ON THE WRECKING BALL!!! 7 1 Quote Link to comment Share on other sites More sharing options...
j_cuevas713 Posted January 8, 2021 Share Posted January 8, 2021 Exciting news! Can't wait to see renders 2 Quote Link to comment Share on other sites More sharing options...
H-Town Man Posted January 8, 2021 Share Posted January 8, 2021 It's great news but hard to wrap my head around it in this context: "Almost 51 million square feet of office space – the equivalent of 50 downtown skyscrapers – is currently vacant in Houston." “Houston’s office market was struggling amid a glut of available space even before the outbreak of the deadly COVID-19 coronavirus,” said Wade Bowlin, president of property services, central division of Madison Marquette. And then there could be post-pandemic headwinds of additional working from home reducing the need for space and M&A and consolidation in energy. https://realtynewsreport.com/houston-office-vacancy-hits-highest-point-since-1980s-madison-marquette/ Building on what thatguysly said, imagine you own a Maserati dealership in River Oaks, and you read in the paper that Houston auto dealerships are doing badly. You know from your books that the Maseratis have been selling like hotcakes, you can't keep them in stock. So do you scale back your inventory because Houston auto dealerships are doing badly? Do you take a wait and see approach based on mixed messages? Or do you buy the building next door to your dealership, tear it down, and double the size of your dealership, and also decide to spend less time reading the paper? Probably the third. It's about market segmentation. The market for brand new office space is different from the market for Class B or even 40-year-old Class A office space. Most of Houston's office stock was built before 1985. And we have a lot of "River Oaks" office tenants (oil companies) that don't care if there's a bargain, they'd rather shell out for the latest and greatest. So we will keep seeing this trickle of new office buildings. 7 Quote Link to comment Share on other sites More sharing options...
iah77 Posted January 8, 2021 Share Posted January 8, 2021 1 hour ago, H-Town Man said: Building on what thatguysly said, imagine you own a Maserati dealership in River Oaks, and you read in the paper that Houston auto dealerships are doing badly. You know from your books that the Maseratis have been selling like hotcakes, you can't keep them in stock. So do you scale back your inventory because Houston auto dealerships are doing badly? Do you take a wait and see approach based on mixed messages? Or do you buy the building next door to your dealership, tear it down, and double the size of your dealership, and also decide to spend less time reading the paper? Probably the third. It's about market segmentation. The market for brand new office space is different from the market for Class B or even 40-year-old Class A office space. Most of Houston's office stock was built before 1985. And we have a lot of "River Oaks" office tenants (oil companies) that don't care if there's a bargain, they'd rather shell out for the latest and greatest. So we will keep seeing this trickle of new office buildings. I think it's worth mentioning right now that rates are so low for these big loans that a new office building can be pretty competitive price wise with the older ones. In other words, the companies are getting a huge upgrade in space while not necessarily getting a huge rent hike. 2 Quote Link to comment Share on other sites More sharing options...
Popular Post Urbannizer Posted January 8, 2021 Popular Post Share Posted January 8, 2021 Quick search does wonders. :) http://test21.kalibratecms.com/ 43 6 Quote Link to comment Share on other sites More sharing options...
Triton Posted January 8, 2021 Share Posted January 8, 2021 What?? No way So what are people staying at Embassy Suites going to see now? Cubicles and office rooms? lol 3 1 2 Quote Link to comment Share on other sites More sharing options...
Naviguessor Posted January 8, 2021 Share Posted January 8, 2021 When They developed that hotel, they always knew that this would happen. Will Love the new view from Disco Green. This is just what was needed here. 6 Quote Link to comment Share on other sites More sharing options...
Triton Posted January 8, 2021 Share Posted January 8, 2021 16 minutes ago, Naviguessor said: When They developed that hotel, they always knew that this would happen. Will Love the new view from Disco Green. This is just what was needed here. Totally. Either way, glad after all these years to finally get the entire area around Discovery Green surrounded by development! 7 Quote Link to comment Share on other sites More sharing options...
monarch Posted January 9, 2021 Share Posted January 9, 2021 ^^^ what a gorgeously designed development. skanska, PLEASE construct this masterpiece. i'm begging you... 5 Quote Link to comment Share on other sites More sharing options...
Bassclef Posted January 9, 2021 Share Posted January 9, 2021 Come on y'all, they're not building this. 2 Quote Link to comment Share on other sites More sharing options...
Tumbleweed_Tx Posted January 9, 2021 Share Posted January 9, 2021 55 minutes ago, Bassclef said: Come on y'all, they're not building this. y'all said that about the Capital Tower. I said it was going up. Skanska moved in to this market and struck gold. 1 Quote Link to comment Share on other sites More sharing options...
H-Town Man Posted January 9, 2021 Share Posted January 9, 2021 2 hours ago, Urbannizer said: Quick search does wonders. :) http://test21.kalibratecms.com/ So do we get a Reunion Tower too or just the Hyatt Regency? 2 5 Quote Link to comment Share on other sites More sharing options...
HOUCAJUN Posted January 9, 2021 Share Posted January 9, 2021 9 minutes ago, H-Town Man said: So do we get a Reunion Tower too or just the Hyatt Regency? You beat me to it! Quote Link to comment Share on other sites More sharing options...
