Elysian Viaduct Replacement
19 hours ago, Houston19514 said:
The freeway is not being relocated at the point where it intersects with Elysian.
i45 is being relocated. there is additional ROW acquisition to account for an elevated i45 to follow the same alignment as i10 where it intersects Elysian street.
there is a cross section in here that is close to Elysian street. http://www.ih45northandmore.com/docs13/10_NHHIP_Seg3_Overview_Layout_PH_1-1.pdf look to the very right of the pdf.
pretty sure his point was that Elysian is elevated above the roadway level, the i45 relocation is going to be an elevated freeway above grade level along almost the entire stretch of the i10 alignment, should we assume that in the location where i45 will intersect Elysian which is already an elevated viaduct above grade, that the elevated i45 will be going even higher above Elysian?
good thing we're removing one elevated freeway from the rich people side of town so we can add an even taller elevated freeway where the poor people live.
edit: found the video that shows elevations and what they will be dealing with where i45 runs along the same alignment as i10.
it is elevated over Elysian. so really tall elevated freeway.
Edited by samagon
  • Like 4
Link to post
  • Replies 186
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
Untitled by Houston Midtown, on Flickr   Untitled by Houston Midtown, on Flickr   Untitled by Houston Midtown, on Flickr   Untitled by Houston Midtown, on Flickr
Smooth sailing !!
From Nextdoor:
Posted Images
Yes, we know I-45 is being relocated. But in the area where the freeway (both I-45 and I-10) crosses Elysian, the freeway is in the same location as I-10 is currently (yes, with expanded right-of-way), obviating Zaphod's concern about what to do with the I-10 right-of-way under Elysian.
Link to post
that's not how I read the question, but whatever, neither here nor there.
both freeways will sit mostly within the current ROW, i10 will go under Elysian, i45 will go over Elysian.
Link to post
38 minutes ago, Triton said:
Don't waste your time. Literally past the curve, it dead ends. Go figure.
I don't see it on the bike plan map, but perhaps the intention is to eventually keep going around the bend in the bayou and connect with the heights trail?
Link to post
  • 5 weeks later...
16 hours ago, HOU_huckster said:
@Avossos Can Harrisburg Blvd underpass serve as a template? It's such a dynamic and colorful experience as one traverses the space.
That's cool! I don't make my way over there often. Need to check that out.
Link to post
24 minutes ago, wilcal said:
Saw this cool photo of the original Elysian Viaduct. This photo is from around 1960.
I loved the Elysian when I had a Taurus SHO. I never did get much above 100 mph, though. There was no place for cops to park, and very little traffic.
  • Like 6
Link to post
Ah I see. That makes more sense.
Edited by zaphod
Link to post
Looking at this photo, the bends of 59 make much more sense - they were avoiding the preexisting rail line, since that probably saved them money.  When did Clayton homes open?  I wonder if it was built before 59 was being planned, or if they were planned at the same time.  That rail line isn't there any more - moved to the east side of Clayton homes.
It's intersting to see the freight stations - there's one on the right side where you can see trucks parked, waiting for stuff to get loaded on to them, and you can see another freight station on McKee, and you can see Union Station in the background, with the sheds stretching multiple blocks east.  Then there's the train yard on commerce and San Jacinto - which is now entirely erased from the map, with the Criminal Courts building at the head of the building, a parking garage, and a bunch of parking lots.  The only evidence that it was there is that Caroline doesn't cross that block.
Link to post
Clayton Homes opened in 1952! So that's quite a while before 59 was built.
Here's another photo that looks north.
  • Like 9
Link to post
Where did you find these from? I've always been trying to find aerials of my area at North Main & 1-45 but nada :(
Link to post
This may be an option for you: https://www.glo.texas.gov/land/land-management/gis/aerials/1940s/harris/index3c.html
These photos I saw in a Chron article about the destruction of the Lyons/Jensen area by the construction of the interstates.
1 hour ago, j_cuevas713 said:
I hope it get's some much needed TLC. I may need to 311 that
I asked Houston TxDOT about it on Twitter awhile back, and they said that it wasn't their bridge.
Just like an hour with a weedeater would make a good bit of difference.
The other issue is that it doesn't really go anywhere. No sidewalks on either side.
Link to post
I feel like Houston has so much but because it gets neglected, nobody knows it exists. This is a small example. But a bigger example is the Amtrak station. So many people have told me they never knew we even had a station that could take them to Nola or LA. It's like Houston doesn't even try to make better use of what it has to offer already. And then all we do is build shiny new stuff on top of it. If I knew this was a solid pedestrian bridge, with access from the Warehouse district, I would park in the Warehouse District, enjoy myself there and then walk to St. Arnolds. It's those little opportunities that this city misses.
  • Like 6
Link to post
That is odd. I thought any bridge crossing a TxDOT maintained road was maintained by TxDOT?
Link to post
I felt it odd as well.
I was planning on following up about it after the Elysian was rebuilt to see if anything happens first.
Sometimes these things fall through the cracks and whoever is responsible doesn't know that they are.
After some flooding in Kingwood, the city was going through to see  which of the drainage ditches needed to be cleaned and someone had to go through the process of figuring out which were city maintained and which were county maintained. IIRC something like 10% of the system was unclaimed by either and the city voluntarily offered to maintain it while they figured out who had to.
Link to post
10 hours ago, HoustonMidtown said:
From Click2Houston:
"drivers should be able to use this new bridge by the end of the year."
https://www.click2houston.com/traffic/2020/06/16/heres-an-update-on-the-elysian-viaduct-bridge-improvements/
Hmmm... Guess I hadn't considered that they haven't even laid the bridge over I-10 yet.
Link to post
I think they are doing the span over I-10 this weekend - there are signs on Chartres alerting to an I-10 closure this weekend
Edited by HoustonMidtown
Link to post
On 6/27/2020 at 11:50 AM, HoustonMidtown said:
50050467568_c902afcab7_k.jpgUntitled by Houston Midtown, on Flickr
50051037891_c72d40bb6f_k.jpgUntitled by Houston Midtown, on Flickr
50051037896_4016e86e2b_k.jpgUntitled by Houston Midtown, on Flickr
50051289782_8bba572f25_k.jpgUntitled by Houston Midtown, on Flickr
I guess making i10 wider through there isn’t part of the redo plan for the highways around downtown? You’d think they’d leave space to accommodate for future expansion.
Link to post
13 hours ago, HoustonMidtown said:
I-10 is closed again this weekend for more work on the bridge
I believe the work this weekend is for the Waco St bridge.
Total Closures to Reconstruct Waco St. Bridge Above IH-10
IH 10 Eastbound Mainlanes at Waco St.
Friday, July 17 [8:30 PM] to Monday, July 20 [5 AM]
Detour: proceed Eastbound on IH 10 Eastbound to exit Waco St.; Follow IH 10 Eastbound Frontage Road to the Waco St. Entrance Ramp.
IH 10 Westbound Mainlanes at Waco St.
Detour: proceed Westbound on IH 10 Westbound to exit Waco St.; Follow IH 10 Westbound Frontage Road to the Waco St. Entrance Ramp.
Link to post
  • Highrise Tower changed the title to Elysian Viaduct Replacement
