Parkside Residences: 43-Story Residential High-Rise For Block 98
largeTEXAS
That last photo of the drill made me think to ask the question--how deep is the bedrock layer here in the Houston area?  I know we have a lot of clay , but I imagine drilling into the bedrock to build your supports can't be that deep.  I have no doubt we have some first hand knowledge on this board.
Tangledwood has all your answers. See the last post on the previous page.
I don't know the answer to your question, but soil boring goes from 100' down to 150'.  Even at 150' there  is still just reddish-brown clay.
This is from a geotechnical report that was done for a project inside the loop.
  • Like 6
Somewhere around 30,000 feet. There are sedimentary rocks at shallower depths, but no bedrock as is known in other parts of the country.
Let me understand this. There are 33 ft of clay followed by 37 feet of sand? Which is then followed by 25 feet of clay, 25 feet of sand, and finally 30 feet of clay.
Amazing. Here in Houston I thought it was clay to the Earth's core.
  • Haha 5
On 9/25/2020 at 11:17 AM, tangledwoods said:
So what your are looking at here are Auger Cast Piles.  In Houston these typically go deep (60 - 120+ feet deep) and rely largely on skin friction with the soil.  We do NOT "go to bedrock" in Houston, it is simply too far down to get to.
Fun fact: Many of the tall building foundations downtown are VERY shallow.  They use a mat slab which is anywhere between 8-15 feet thick across the entire footprint of the building.
Thank you tangledwoods very much for helping me to understand these factors about the foundations of tall structures in our own unique Houston coastal soil and ground structure !  I had also wondered all these years if we had any bedrock within striking range so to speak of the sand and gumbo clay of east and se Houston all the way to the coast.  It seems as though we do, but it's just too far down below the surface to be economically feasible to use it.
Which leads me to my next comment and curiosity (or my ongoing "someday dream") for downtown. And, that is the hope of another but much higher supertall tower like one approaching or exceeding 100 stories and how they would be able to support this super structure from below.  I do know that it's going to happen ONE DAY in the future and I also believe we Houstonians want something that is the tallest and most gorgeous supertall in the U.S. for our own Houston and Texas pride.  All which would be well worth the cost of building such an iconic building or buildings.  Now, if we could only find dedicated funding from both federal and local municipal funds to help out some awesome developer along with a very generous proud Houstonian philanthropist with plenty of financial resources to make it happen in our lifetimes.  Hmmm......  😀
Edited by ArtNsf
35 minutes ago, tangledwoods said:
We have very naughty layers to our soil.  Clay is not great and sand is not great but neither are of any particular concern, you just design a foundation system that jives with that soil.  The problem we run into a lot is layering like Paco showed from his geotech.  We actually have a decent amount of "underground streams" or sandy layers which really screw with your foundations.  You either have to keep it high and tight (spread footings / mat foundation) OR you have to get past the sand into a bearing layer (drilled piers / ACP / etc).
TLDR: dirt aka "soil" is extremely complicated / important and also hella boring.  BUT it is a huge part of a project cost and the developer receives virtually no ROI to your foundation of choosing.  Which is why we spend a lot of time during design arguing about and pricing options for different foundation designs.
So how long can any of these buildings last if they're not on rock?
When talking about a building foundation, no properly designed or built foundation system will ever be the linchpin in a building lifespan.  A good foundation will last FAR longer than anything built above it.  NOTE: I am talking about large public or private buildings, I am not talking about under 6 story timber framed anything.
FYI foundations are subject to differential settlement in our soils (differential meaning that your building is falling or rising differently from adjacent ones).  For a building like Texas Tower or other tall structures you expect to see 3 windows of settlement:
  1. initial (foundation install to right after install)
  2. during construction (as the concrete or steel frame adds weight the building sinks)
  3. upon completion
During phase 1-2 you MIGHT see 2-6 inches (it will all be engineered and expected).  Upon completion you will see less than an inch and then it becomes part of the neighborhood and is no longer subject to any tangible differential settlement.
Foundation failures are extremely rare but they do happen.  A good recent example:
https://en.wikipedia.org/wiki/Millennium_Tower_(San_Francisco)#Sinking_and_tilting_problem
  • Like 5
  • Thanks 4
1 hour ago, thatguysly said:
Quite a while. Nothing in Houston is on rock. From skyscrapers to refineries to airports everything is on pilings.
Yes. But whether other buildings in Houston are on rock will not affect the lifespan of downtown skyscrapers. If a mat foundation tilts a little, it affects a 1,000 ft building more than it affects a refinery or an airport. And there is much more weight on it to make it tilt.
  3. upon completion
So in 100 or 200 years, our tallest towers are still standing perfectly straight? Or does some other factor (brittleness of structural frame?) get them before then?
At a more macro level, we have clay layers interspersed with aquifer layers for several thousand feet. Lots of sand and clay, not much that's solid.
Depends. If things stay as they are, centuries.
  • Like 5
11 minutes ago, nate4l1f3 said:
Was Discovery Green named after the Discovery Shuttle?
I would say, named with the shuttle in mind as a sort of vague tribute to the city's connection with space exploration. Not so much the shuttle itself as the whole spirit of NASA's endeavors over the years.
And with the double meaning of being a place for kids to discover things and for Houstonians to discover what urbanism is.
Edited by H-Town Man
  • Like 7
I was watching the Challenger documentary on Netflix last night and it kinda hit me with all the Discovery shuttle talk.
12 hours ago, hindesky said:
While checking out the Trammel Crow and Andres websites they have 2 conflicting images of what this building will look like, I sure hope it ends up being the latter.
There were multiple renderings released over a few years for this. The bottom picture is the most recent and supposedly final rendering.
  • Like 4
Crawler cranes are to be dismantled this weekend, street closures.
1500 Walker [La Branch & Crawford]
Friday, October 16 [7PM]  to Sunday, October 18 [7pm]
Closed for a Crane de-mobilization.
Detour: Crawford, left on Capitol, left on LaBranch.
Contact: Jack Koop, Andres Construction, 214-521-2118
  • Like 6
If I were a bettin man, I would put money on @Paco Jones and the stuff he posted. So my money is on the final render.
  • Like 5
On 10/21/2020 at 9:27 AM, HouTXRanger said:
Although I'll never be able to afford it, damn is that a slick looking tower. I wonder if it'll be one of the city's "Historic" landmarks by 2100 . . .
Either that or they'll spend six months chipping all of these pilings out.
Quote
Putzmeister = she fancy!
Most people have no idea how incredible advanced the concrete business has gotten.  You can look at things like these placing booms or the self climbing formwork (checkout the latest pics on The Allen for a good example).
What is going to be really interesting in the next 24 months is if any of the new developer jobs go to steel frame.  Steel prices have collapsed and concrete hasnt really dropped.  Wood products are going up in price and I think we might see 1-2 jobs switch to steel if they aren't too invested in the structural design.
I've been wondering this: is there an advantage over using steel vs concrete/wood? I've seen your question in other threads and just wondered since no onw has really answered it.
Quote
In developer world advantage = dollars.  So that is why we see so many concrete frames for tall buildings.  Back when the Chevron new 50+ story was real, that project was slated to use steel.
There are really 2-3 positives to steel vs concrete:
  1. Steel typically has a lower interstitial depth (distance from bottom of structure to finished floor above). On a tall building, this can add up to decent savings:  if your structure reduces 5" per floor then on that 50 story building you could cut 21ft of facade out and still have equal interior spaces.
  2. Steel typically is faster than concrete.  On a tall building steel will go up much faster than a concrete frame.
  3. Steel is more flexible.  If you have a building with geometry, long spans, or variable column spacing, steel can be easier to work with.
  4. Bonus: steel is seen as more environmentally friendly (not that Texas cares too much).  Concrete (specifically the cement used in concrete) is responsible for 8% ish of all CO2 emissions in the world.  Both steel and concrete are recyclable but steel is more often recycled and a lower carbon footprint.
  • Like 9
Interesting. So what are the advantages of concrete over steel? Isn't it usually cheaper? Is it more fire resistant? More rigid?
  1. Concrete frames are almost always cheaper (but that might be changing)
  2. Concrete is more flexible for slab edge facade anchorage (unless you are using lost of post tensioning)
  3. Concrete doesn't typically require additional fireproofing
  • Like 5
  • Thanks 2
And rigidity? Do concrete buildings sway as much in the wind?
Quote
i am NOT an engineer, but from the construction side we do talk about movement (sway) and it isnt really a consideration until you get very very tall (then you get fun things like tuned mass dampers).
In my experience, there is no difference between concrete and steel on building sway.
  • The title was changed to Parkside Residences: 43-Story Residential High-Rise For Block 98
  • The title was changed to Parkside Residences: 43-Story High-Rise For Block 98
