Popular Post Nate99 Posted April 29, 2015 Popular Post Share Posted April 29, 2015 10 Quote Link to comment Share on other sites More sharing options...
monarch Posted April 29, 2015 Share Posted April 29, 2015 ^^^ cool illustration nate99! Quote Link to comment Share on other sites More sharing options...
bobruss Posted April 29, 2015 Share Posted April 29, 2015 I can't remember but is this going to be clad in brick or Stucco like the Suzanne? I hope its brick. Quote Link to comment Share on other sites More sharing options...
toxtethogrady Posted April 29, 2015 Share Posted April 29, 2015 You know, if the Astros remain in first place, those apartments are going to be in high demand. Â The Astros' magic number is 139. 1 Quote Link to comment Share on other sites More sharing options...
cspwal Posted April 29, 2015 Share Posted April 29, 2015 Agreed. All part of the plan.   Looks like brick Quote Link to comment Share on other sites More sharing options...
j_cuevas713 Posted April 30, 2015 Share Posted April 30, 2015 Man talk about having an awesome vibe outside the stadium. We are easily going to have one of the best baseball environments for national media. 2 Quote Link to comment Share on other sites More sharing options...
Luminare Posted April 30, 2015 Share Posted April 30, 2015 I can't remember but is this going to be clad in brick or Stucco like the Suzanne? I hope its brick. It looks like it will be all brick. A redish brick and a tanish brick. then you have the split face stone veneer at the bottom portion. Quote Link to comment Share on other sites More sharing options...
bobruss Posted May 1, 2015 Share Posted May 1, 2015 I actually went down today and they are putting up the stone and brick now on the west side of the building. Looks good.So glad to see the brick. 3 Quote Link to comment Share on other sites More sharing options...
hindesky Posted May 9, 2015 Share Posted May 9, 2015 Spotted the white brick. Â 6 Quote Link to comment Share on other sites More sharing options...
monarch Posted May 9, 2015 Share Posted May 9, 2015 ^^^ wow, that white stone is of such thickness and high quality, that it shall render this place virtually indestructible. Â it's going to be quite expensive to reside at this magnificent edifice! Â 3 Quote Link to comment Share on other sites More sharing options...
Purdueenginerd Posted May 10, 2015 Share Posted May 10, 2015 Aluminium framing for the support structure! They can be a little heftier with their architectural details. Â Â 1 Quote Link to comment Share on other sites More sharing options...
Popular Post urbanize713 Posted May 10, 2015 Popular Post Share Posted May 10, 2015 A little different perspective from a week ago 12 Quote Link to comment Share on other sites More sharing options...
Montrose1100 Posted May 10, 2015 Share Posted May 10, 2015 Great perspective, it's a huge building! Quote Link to comment Share on other sites More sharing options...
cspwal Posted May 10, 2015 Share Posted May 10, 2015 Minute Maid park and the Toyota center are going to look so urban and developed around in those ariel shots the TV always runs during commercials - no sea of parking lots but instead high rises and mid rises 3 Quote Link to comment Share on other sites More sharing options...
hindesky Posted May 10, 2015 Share Posted May 10, 2015 Aluminium framing for the support structure! They can be a little heftier with their architectural details. Â Â Do you think it's aluminum? I just assumed it was galvanized steel. Doesn't stone/brick simply just sit on top of the brick below it or is it anchored to the wall? Quote Link to comment Share on other sites More sharing options...
Luminare Posted May 11, 2015 Share Posted May 11, 2015 Do you think it's aluminum? I just assumed it was galvanized steel. Doesn't stone/brick simply just sit on top of the brick below it or is it anchored to the wall? It would either be galvanized steel or Stainless. The stone would sit on a concrete lip that is part of the foundation. The brick would be stacked on top of that. Masonry ties helps keep the stone and brick attached to the structure. Lets also remember that even though we see the hollow wall off the galvanized steel, covering the those studs would be a layer of gypsum board (the yellow looking board), then you will have rigid insulation on top of that. Then an air gap and then the stone/brick after that with masonry ties holding the brick and are attached to the studs. Quote Link to comment Share on other sites More sharing options...
Purdueenginerd Posted May 11, 2015 Share Posted May 11, 2015 The framing looked like aluminum to me. The studs and everything were that way as well. No way its galvanized steel frame. Overtly expensive with no reason to galvanize it (its not exposed to elements). Stainless steel would be even more expensive, and weaker. Stainless steel has a lower yield strength than carbon steel. I'll go back to the photos later, but I'm pretty confident it was an aluminum frame structure. Quote Link to comment Share on other sites More sharing options...
Purdueenginerd Posted May 11, 2015 Share Posted May 11, 2015 Well, I looked at the photos. It could be steel. I thought the metal framing studs were only offered in aluminum. But they got it in steel as well http://www.menards.com/main/building-materials/metal-framing/c-5695.htm My Apologies. 1 Quote Link to comment Share on other sites More sharing options...
Luminare Posted May 11, 2015 Share Posted May 11, 2015 Well, I looked at the photos. It could be steel. I thought the metal framing studs were only offered in aluminum. But they got it in steel as well  http://www.menards.com/main/building-materials/metal-framing/c-5695.htm  My Apologies.  I'm sure there are people that will use aluminum studs, but in most cases (in my very very short career thus far ) I've dealt with mostly galvanized steel studs. I also say stainless steel because I'm working on a small job right now where the owner is calling for Stainless steel because they have had problems in other buildings where the connection point of the stud and concrete floor/foundation the stud would rust so they want stainless steel to help counteract that. Quote Link to comment Share on other sites More sharing options...
Purdueenginerd Posted May 11, 2015 Share Posted May 11, 2015 yeah. I deal mainly in the industrial realm. So my experiences with housing framing (beyond traditional wood) is limited-- I had assumed aluminum was used when I saw it several months ago. Â Quote Link to comment Share on other sites More sharing options...
toxtethogrady Posted May 13, 2015 Share Posted May 13, 2015 ^^^ wow, that white stone is of such thickness and high quality, that it shall render this place virtually indestructible. Â it's going to be quite expensive to reside at this magnificent edifice! Â Â You mean, it got stone and I missed it? 1 Quote Link to comment Share on other sites More sharing options...
lockmat Posted May 14, 2015 Author Share Posted May 14, 2015 Looks like brick   Is it just me or does the garage facade in the middle resemble a train station? Definitely seeming like a very nice project.  Man talk about having an awesome vibe outside the stadium. We are easily going to have one of the best baseball environments for national media.  Everything except the standalone parking garage being built directly south of MMP. 1 Quote Link to comment Share on other sites More sharing options...
nate4l1f3 Posted May 14, 2015 Share Posted May 14, 2015 Is it just me or does the garage facade in the middle resemble a train station? Definitely seeming like a very nice project.Everything except the standalone parking garage being built directly south of MMP.Totally with you on this one. A row of unique bars/restaurants would be cool on that street. Quote Link to comment Share on other sites More sharing options...
Howard Huge Posted May 14, 2015 Share Posted May 14, 2015 Is it just me or does the garage facade in the middle resemble a train station?Well I think the whole thing was meant to look like Union Station next door, right? 2 Quote Link to comment Share on other sites More sharing options...
lockmat Posted May 14, 2015 Author Share Posted May 14, 2015 Well I think the whole thing was meant to look like Union Station next door, right? Yeah, I always thought the architecture and colors were meant to match MMPs train station, but what stuck out to me this time was the garage facade. I hadn't noticed that before. Quote Link to comment Share on other sites More sharing options...
Houston19514 Posted May 14, 2015 Share Posted May 14, 2015 Is it just me or does the garage facade in the middle resemble a train station? Definitely seeming like a very nice project.Everything except the standalone parking garage being built directly south of MMP.What standalone parking garage? Quote Link to comment Share on other sites More sharing options...
lockmat Posted May 14, 2015 Author Share Posted May 14, 2015 What standalone parking garage? It's a 300-car parking garage for the Incarnate Word Academy. #41 on the map. Big bummer, I know. http://downtownhouston.org/site_media/uploads/attachments/2015-04-09/150408_Development_Map__Renders_11X17_1.pdf Quote Link to comment Share on other sites More sharing options...
cloud713 Posted May 14, 2015 Share Posted May 14, 2015 Why can't those 300 spots be incorporated into another development? That would be ideal.. Sort of like Marriotts deal to use 700(?) spaces of the GHP garage. Quote Link to comment Share on other sites More sharing options...
Naviguessor Posted May 14, 2015 Share Posted May 14, 2015 It's the Catholic Church. That's why. Add it to the list. Quote Link to comment Share on other sites More sharing options...
lockmat Posted May 14, 2015 Author Share Posted May 14, 2015 Why can't those 300 spots be incorporated into another development? That would be ideal.. Sort of like Marriotts deal to use 700(?) spaces of the GHP garage. Â I think our best hope is that in 20-30 years land prices are so high that they would tear it down and do as you suggest with a developer who wants to utilize that spot. Â I guess the timing is not right as of now. They need the parking spaces but there's not a developer that needs or wants to do that deal at the moment. Â In the meantime, let's hope for ivy on the sides! 1 Quote Link to comment Share on other sites More sharing options...
