HomeAloneIndeed Posted November 16, 2008 Share Posted November 16, 2008 The day I closed on my home, my neighbor completed work on an impressive fence. Two years later-- I learn that it is not legal in Texas for a neighbor to build a dam- with a fence on top, that causes water to stand in the other neighbors yard (mine). I live uphill from them.My neighbor refuses to modify their 'dam with a wrought iron fence on top' Will or can the City 'enforce modification' ? Has too much time passed for city inspectors to do anything? Do i need to go to Don Vito Corleonni?thanks Link to comment Share on other sites More sharing options...
BryanS Posted November 16, 2008 Share Posted November 16, 2008 when you say 'dam' ... what exactly do you mean? How high is the earthen structure from grade? Link to comment Share on other sites More sharing options...
RedScare Posted November 16, 2008 Share Posted November 16, 2008 Absolutely, she can be forced to modify it. If you live in the city, start with city officials, perhaps code enforcement. Then move up to your councilperson. You can also sue, but that costs money, and the city should enforce its codes. Link to comment Share on other sites More sharing options...
musicman Posted November 16, 2008 Share Posted November 16, 2008 The day I closed on my home, my neighbor completed work on an impressive fence. Two years later-- I learn that it is not legal in Texas for a neighbor to build a dam- with a fence on top, that causes water to stand in the other neighbors yard (mine). I live uphill from them.so your water would drain onto your neighbor's yard if the dam wasn't there? i don' t about the codes in austin but here it is against code if water from one property drains onto another. Link to comment Share on other sites More sharing options...
memebag Posted November 16, 2008 Share Posted November 16, 2008 You're looking at it the wrong way. Enjoy the free water. Link to comment Share on other sites More sharing options...
crunchtastic Posted November 16, 2008 Share Posted November 16, 2008 You're looking at it the wrong way. Enjoy the free water.Meme, I just noticed your avatar has had some work. Is ole' Orson the lost member of Los Lobos, or something? Link to comment Share on other sites More sharing options...
RedScare Posted November 16, 2008 Share Posted November 16, 2008 so your water would drain onto your neighbor's yard if the dam wasn't there? i don' t about the codes in austin but here it is against code if water from one property drains onto another. Not true. If the natural flow of the water is onto the other property, that is fine. It is merely illegal to divert the water onto another's property. Living in flat Houston, you might not realize that it is common for water to flow downhill. Link to comment Share on other sites More sharing options...
memebag Posted November 16, 2008 Share Posted November 16, 2008 Meme, I just noticed your avatar has had some work. Is ole' Orson the lost member of Los Lobos, or something?He's hiding from The Man. Link to comment Share on other sites More sharing options...
TexasVines Posted November 16, 2008 Share Posted November 16, 2008 I would be very careful pursuing this as you could very well find yourself in violation and in for some expensive drainage modifications if your neighbor can prove that things on your property create excessive runoff Link to comment Share on other sites More sharing options...
